Home > Puma (Tdci) > Glow plug faulty - replace one or all of them?
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
It appears I have a faulty No 1 glow plug. I wondered if there was any merit in replacing them all while access is available or if it's best just to replace the faulty one?
I note from other posts they can be difficult to get out so maybe they're best left alone, on the other hand, maybe at 6 years old it's a good idea to remove them so that at some time in the future they will still be removable?
What's the wisdom of the forum? 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #773535 17th May 2019 10:13am
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I replaced mine last year (at 7 years old) none of them were working! only one got luke warm, the rest did not.
Do them all.
Twist / turn them as you pull / lever them out. 1953 80"
1987 mini city e
2011 90"
Post #773767 18th May 2019 8:54pm
Caterham
so with none of them working how bad did things get?
what I mean is with one not working do you even notice. if not this should be considered against the potential problems caused should it shear off while trying to remove it?
Post #773787 18th May 2019 10:01pm
mick
All itโ€™s not an easy job
Post #773793 18th May 2019 10:22pm
MR_JAMES
Maybe a second or two slower to start in the winter but I didn't even realise. I wanted to clean the inlet manifold of muck and thought to do them at the same time as they are not expensive.
I found it easy but then am good with the spanners! 1953 80"
1987 mini city e
2011 90"
Post #774104 20th May 2019 8:21pm
Shouldn't there be DTC's logged with glow plug faults? Obviously no MIL or you'd have noticed.
I thought they were on the radar so to speak with ECU monitoring. No Guts, No Glory.
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #774108 20th May 2019 8:33pm
MK
Are glow plugs really needed on moderate climates? Puma 110" SW
Post #774160 20th May 2019 10:39pm
