Home > Puma (Tdci) > Power steering fluid
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Hu Guys
I’m aware this has topic has been skirted over a few times on other threads .
I can see that land rover recommend the Texaco cold climate PSF but I’m struggling to find anyone nearby who stocks the stuff .
I need to change the power steering box today as its the only window of opportunity I have.
So the question is can I pop a good quality steering fluid in instead and if not why not ?!
I’ve been on comma oils website and popped in my number plate , they don't recommend any of their products. However if i put a pre 2007 model into the search, they appear to manufacture a fluid for that. Same steering box as 2007 on.
So even more baffled https://www.instagram.com/hustynminepark/
Post #771857 7th May 2019 8:25am
kmac
Land Rover dealers can provide the specified Power steering fluid. Probably cost an arm and a leg though
Post #771883 7th May 2019 11:38am
Bluest
Drop forum sponsor Opie Oils a line and see what they recommend. Then come back here and let the rest of us curious souls know Very Happy 2007 110 TDCi Station Wagon XS
Post #771887 7th May 2019 11:43am
Bluericky
Motul 45750 is their recommendation .
I just spoke to the local Land Rover specialist and he repeats what others say. Only use Texaco LR Cold Climate 14315
Luckily he’s got a bottle or two I can purchase but no idea what you’d do if you were in the arse end of nowhere in deepest Africa !! https://www.instagram.com/hustynminepark/
Post #771899 7th May 2019 12:40pm
MK
RAVENOL SSF Special Servolenkung Puma 110" SW
Post #771935 7th May 2019 3:43pm
Bluericky
So I went to pick some up from a closer Land Rover specialist than the one I rang , they said they use Morris CHF and always have and apparently it’s the same stuff in a different bottle !
Post #771947 7th May 2019 4:56pm
oilman
It looks to be Pentosin CHF 11s based, the Texaco as far as I am aware is the only approved CHF fluid by Land Rover for Land Rover but I do not see why any quality CHF 11s fluid would not be suitable.
Cheers,
Guy Use the code DEF2 and get 10% Club Discount
View Opie Oils Current Offers Here > >
oilman's website: http://www.opieoils.co.uk/ - register for news and offers
email: sales@opieoils.co.uk
phone: 01209 202944
Post #772473 10th May 2019 2:14pm
I'd have thought if it meets the sane specs then its fine. I'd assume LR was sticking to brands again unnecessarily.
I had similar with the anti freeze, LR recommended Texaco then too yet Motul for example meets the same specs.. No Guts, No Glory.
Post #772482 10th May 2019 3:26pm
