Home > Puma (Tdci) > Power steering fluid |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 |
Hu Guys
I’m aware this has topic has been skirted over a few times on other threads . I can see that land rover recommend the Texaco cold climate PSF but I’m struggling to find anyone nearby who stocks the stuff . I need to change the power steering box today as its the only window of opportunity I have. So the question is can I pop a good quality steering fluid in instead and if not why not ?! I’ve been on comma oils website and popped in my number plate , they don't recommend any of their products. However if i put a pre 2007 model into the search, they appear to manufacture a fluid for that. Same steering box as 2007 on. So even more baffled https://www.instagram.com/hustynminepark/ |
7th May 2019 8:25am |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 |
Land Rover dealers can provide the specified Power steering fluid. Probably cost an arm and a leg though
7th May 2019 11:38am |
Motul 45750 is their recommendation .
I just spoke to the local Land Rover specialist and he repeats what others say. Only use Texaco LR Cold Climate 14315 Luckily he’s got a bottle or two I can purchase but no idea what you’d do if you were in the arse end of nowhere in deepest Africa !! https://www.instagram.com/hustynminepark/ |
7th May 2019 12:40pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2429 |
RAVENOL SSF Special Servolenkung Puma 110" SW
7th May 2019 3:43pm |
So I went to pick some up from a closer Land Rover specialist than the one I rang , they said they use Morris CHF and always have and apparently it’s the same stuff in a different bottle !
Click image to enlarge https://www.instagram.com/hustynminepark/ |
7th May 2019 4:56pm |
oilman Site Supporter Member Since: 19 Mar 2009 Location: Cornwall Posts: 511 |
It looks to be Pentosin CHF 11s based, the Texaco as far as I am aware is the only approved CHF fluid by Land Rover for Land Rover but I do not see why any quality CHF 11s fluid would not be suitable.
Cheers, Guy Use the code DEF2 and get 10% Club Discount View Opie Oils Current Offers Here > > oilman's website: http://www.opieoils.co.uk/ - register for news and offers email: sales@opieoils.co.uk phone: 01209 202944 |
10th May 2019 2:14pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20466 |
I'd have thought if it meets the sane specs then its fine. I'd assume LR was sticking to brands again unnecessarily.
I had similar with the anti freeze, LR recommended Texaco then too yet Motul for example meets the same specs.. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
10th May 2019 3:26pm |
