Home > Puma (Tdci) > Injector seal?? (and the rest of my to do list)
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
See below pic. I assume injector seal 3 has gone. Is it worth to change all 4 or would you only change the third one?
It's starting to get a very very long list:
1. Coolant loss, luckily it drips so hopefully no head gasket. But Haven't found the leak
2. Aircon isn't working, haven't found leak
3. transfer box is leaking heavily
4. Stubs between exhaust manifold and turbo are still coming loose
5. Wobble at 50-60 mph, suspect steering damper
6. Seals shot at intake manifold (i guess)
7. And last but not least clutch is almost shot. Still have to decide between clutchfix and lof extreme clutch
Luckily the wipers are still operational Thumbs Up a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #770193 26th Apr 2019 12:37pm
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
Change all 4 seals including the two securing bolts. Ensuring they get torqued up to the correct figure after as they’re stretch bolts and known for snapping. You may also need a few more seals like the rocker cover. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #770195 26th Apr 2019 12:40pm
MK
make sure you clean the injector/washer seats. Puma 110" SW
Post #770199 26th Apr 2019 12:48pm
Tdi4
So I need something like this:
Or is this too much? a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #770200 26th Apr 2019 12:49pm
Tdi4
And how can I clean them the best way? a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #770201 26th Apr 2019 12:50pm
MK
with a skinny screwdriver/bolt wrapped with cloth. Just to remove any debris. No need to replace the clamps I would say. Puma 110" SW
Post #770202 26th Apr 2019 12:52pm
dorsetsmith
Post #770209 26th Apr 2019 1:48pm
Tdi4
Thnx. I’ve read the manual and i’ve got 2 questions.
1. Do I also need new fuel lines?
2. If using the 4 original injectors do I need to do the relearn? a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #770210 26th Apr 2019 1:57pm
MK
Most people use same lines. You should not need to go through the relearn process. Needless to say you fit each injector back to its original position. Puma 110" SW
Post #770229 26th Apr 2019 3:55pm
Island Rover
United States 2008 Defender 110 Puma 2.4 CSW Galway Green
To me that doesn't look like a bad injector seal, but rather a bad seal at the hard line leading to the injector. These engines do have a lot of problems with the injector seals and you could also have that problem - in which case that kit you showed would be exactly what you need. But it looks to me like the leak is actually at the acorn joint of the hard line. The manual recommends that you replace the hard lines if you remove the injectors. I bought a new set of hard lines when I did my injector seals, but didn't use them because the hard lines all looked fine.
Post #771037 1st May 2019 12:09pm
Island Rover
dorsetsmith wrote:
see link below
https://www.defender2.net/forum/topic65733.html
If you are using the four original injectors, which will probably all be fine once they are cleaned up, and put them all back in their original locations they will be fine. No need to re-learn them.
I have had mine in and out about three times while trying to sort out my injector seal issues and have not had any problem with the injectors as long as I put them back in the same place they came from.
Post #771038 1st May 2019 12:11pm
Tdi4
Thnx for the info. I'll have a look at it by my mechanic a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #771039 1st May 2019 12:20pm
Tdi4
I think I’ll clean the arena so i can see if it is the seal Or the line. Idea a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #771042 1st May 2019 12:31pm
Fernando
Argentina 2008 Defender 110 Puma 2.4 SW Bonatti Grey
It is a job that I have to face soon. Are the injectors easy to remove, or do they usually lock on carbon?
How do you clean the seat on the cylinder cover?
regards
Post #771176 2nd May 2019 10:30am
dgardel
Italy
It's a little of "humidity" not a big leak........ Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #771206 2nd May 2019 1:19pm
