Home > Maintenance & Modifications > What am I missing?
alby 110
Australia 2005 Defender 110 Td5 SW Chawton White
What am I missing?
Hi all
Just trying to do a wheel bearing and cannot budge the nut , have I missed something or is it stuck fast?
Post #769955 25th Apr 2019 2:48am
alby 110
Sorry some reason pic won’t load, td5 with the single locking nut.
I have straightened the locking plate but still cannot move the nut to take hub off.
Post #769956 25th Apr 2019 2:52am
bankz5152
I had to remove one of mine with a 3ft scaff bar. Make sure you use a proper 52mm socket.
Second nut had to be drilled off - Use a stepped drill bit
They are just Censored TIGHT
Once youve done it once itll come undone easy with a basic buzzgun Instagram @defender_ventures
Empire Tuning - Agent
Post #769957 25th Apr 2019 5:01am
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
No the should just undo. Sounds like you need a decent length breaker bar and a possible handle extension to increase the torque.
Post #769959 25th Apr 2019 5:44am
hank
They've always flown off for me, sometimes need an extension bar. > 110 XS Double Cab
Post #769960 25th Apr 2019 5:54am
There should not be a "locking plate" with the single stake nut.
As others have said, one the staking has been released it should just unscrew, so what you are missing is probably a long enough handle on the socket.
Generally (though not good practice) they will unscrew without unstaking the nut provided that you use an adequate length breaker bar.
Post #769997 25th Apr 2019 11:11am
dorsetsmith
52mm 6 point deep socket and 40 inch breaker bar
Post #770001 25th Apr 2019 11:53am
alby 110
Thanks all for the tips,long bar did not work I had to get an impact gun onto it.
Post #771465 4th May 2019 8:59am
landy andy
Now replace them with the old two nut system. It’s far better, and doesn’t ruin stub axles.
Post #771469 4th May 2019 9:13am
