Home > Maintenance & Modifications > What am I missing? |
alby 110 Member Since: 04 Mar 2013 Location: Brisbane Posts: 3 |
Hi all
Just trying to do a wheel bearing and cannot budge the nut , have I missed something or is it stuck fast? |
25th Apr 2019 2:48am |
Click image to enlarge Sorry some reason pic won’t load, td5 with the single locking nut. I have straightened the locking plate but still cannot move the nut to take hub off. |
25th Apr 2019 2:52am |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 747 |
No the should just undo. Sounds like you need a decent length breaker bar and a possible handle extension to increase the torque.
25th Apr 2019 5:44am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2314 |
They've always flown off for me, sometimes need an extension bar. > 110 XS Double Cab
25th Apr 2019 5:54am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17541 |
There should not be a "locking plate" with the single stake nut.
As others have said, one the staking has been released it should just unscrew, so what you are missing is probably a long enough handle on the socket. Generally (though not good practice) they will unscrew without unstaking the nut provided that you use an adequate length breaker bar. |
25th Apr 2019 11:11am |
52mm 6 point deep socket and 40 inch breaker bar
25th Apr 2019 11:53am |
Thanks all for the tips,long bar did not work I had to get an impact gun onto it.
4th May 2019 8:59am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5789 |
Now replace them with the old two nut system. It’s far better, and doesn’t ruin stub axles.
4th May 2019 9:13am |
