Home > Maintenance & Modifications > New Ram Mount for defender dash |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 587 |
I have the same issue. I was quite disappointed when I realised this happened. Watching with interest
15th Apr 2019 7:03pm |
newton-tony Member Since: 18 Sep 2016 Location: Wiltshire Posts: 122 |
I bolted mine through the ash tray and haven't had any problems - I have a large phone and not had any issues with rotating etc.
Apologies if I have not understood the problem you guys are having. Click image to enlarge Click image to enlarge |
15th Apr 2019 7:22pm |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 |
Is that attached with self tappers? 2002 110 td5
15th Apr 2019 7:30pm |
No, I took the ash tray out and removed the cover - then drilled holes and used small bolts to attach the RAM mount
15th Apr 2019 7:33pm |
Hi Jimb, what have you used to connect the Ram mount to the dash as I can not tell from your photograph?
We have used ram mounts for holding iphones, ipads and tough books. The only time we have had movement is on extremely rough roads. Brendan |
15th Apr 2019 7:57pm |
https://www.mudstuff.co.uk/products/ram-mo...mount.html
It’s this one. It is marketed as utilising the central dash screw behind the ash tray. 2002 110 td5 |
15th Apr 2019 8:11pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2644 |
I used to use the Ram Mount Twist Lock Suction Base until a few weeks back when it decided to fall off, got spotted by the motion detector then set the alarm off. Fortunately for the neighbours they got to hear the two uprated horns I fitted a few years ago.
Its amazing how fast you can run when you think your motor is being tampered with. I took the tapered base off the suction section then attached it to the inner side of the windscreen vent (TD5) with a longer screw. I did not screw the other side to the dash but instead used 3m High Bond Tape so it can come off again without leaving a hole. I have also done the same for the passenger side to. |
15th Apr 2019 8:33pm |
