Home > In Car Electronics > How to disarm alarm on a 2015 Puma?
Countryman2
United Kingdom 2015 Defender 90 Other XS CSW Scotia Grey
Hi
I need to disable the alarm to go on a ferry. There is no button on the dash and the manual says that even turning the key in the lock will set it. Not that my key seems to turn the lock anyway and I don’t want to force it. Has anyone worked out how to do this? The fob only has two buttons, lock and unlock. Thanks.
Post #763574 15th Mar 2019 10:21am
dorsetsmith
lock it with you keys
Post #763575 15th Mar 2019 10:35am
Countryman2
Thanks. But manual,says locking with the key will also set the alarm, unless that is wrong.
Post #763576 15th Mar 2019 10:41am
Likeomg
Why do you need to disable the alarm for the ferry ? Shocked
Pets in the car?
Post #763577 15th Mar 2019 10:41am
Countryman2
Assumed motion could set it off?
Post #763579 15th Mar 2019 10:51am
Likeomg
probably unlikely in a defender, which ferry route?
most routes from the uk are fairly short anyway, if your battery is in good health shouldn't be a issue even if it does go off...
well if your going to Santander it's maybe not a good idea Whistle
Post #763580 15th Mar 2019 11:01am
I can stand on the roofrack on mine and rock it vigorously from side-to-side and up-and-down and it doesn't set the alarm off. I don't think a ferry will be a problem.
Post #763599 15th Mar 2019 12:26pm
Swine&Small
Thieves don't even seem to set the alarm off, why should a ship Big Cry 1983 Series 3 Pick up in Marine Blue
1967 Morris Traveller
1966 Morris Convertible
2012 VW T5 Camper
Quod Abundat Non Obstat.
Post #763601 15th Mar 2019 12:41pm
Darcy Fairfax
England 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Rolling with laughter
Post #763603 15th Mar 2019 12:52pm
gcc130
I lock mine with the key everyday with my dog in the cab and the alarm never goes off, if I forget and use the remote the alarm will go off soon after.
Post #763605 15th Mar 2019 1:04pm
donmacn
FWIW, I'm regularly on Cal-Mac ferries to the Hebrides. Maybe the seas are rockier here.....?
There's usually a poster somewhere on the car deck advising that alarms should be disabled - but clearly many folk don't read them; don't know how to do that; or their cars don't have that facility.
Our 'other car' a Yeti, has a button on the bottom of the B pillar which alters the alarm set function for ferry crossings.
I know it's a pain when standing outside (on a good day!) and the car alarms are going off repeatedly. So, if I had a car which allowed this, and there was a way to keep it secure and avoid the alarm going off, I'd use it.
Having said all that, with the LR I normally leave the keys in the ignition and the doors unlocked... I just don't perceive there to be any real risk on the ferries I use. I guess I might not do that on other sailings. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #763609 15th Mar 2019 1:21pm
Swine&Small
Good idea, as long as some scrote does not steal your key ! 1983 Series 3 Pick up in Marine Blue
2012 VW T5 Camper
Post #763611 15th Mar 2019 1:28pm
donmacn
Aye, like I say, I probably wouldn't do it anywhere else other than the w. or n. of Scotland.
We went across to the Netherlands last year, from Newcastle, and I'm pretty sure I locked it then.
I think the main thing here though isn't about a car running its battery flat sounding an alarm, but probably for the benefit of the crew who won't want to be working alongside several car alarms sounding off all the time. Donald
in the past..
Post #763614 15th Mar 2019 1:46pm
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
Been going across the channel for years and always locked with the fob when collecting the car at the end of the voyage sometime's loads of a alarms going off the good new is with the water tight doors closed you can't here them Smile
Post #763618 15th Mar 2019 2:03pm
discomog
Lock it with the key only, not the fob which will disable the volumetric alarm. I wasn't aware that the Puma alarm had tilt or shock sensors, only doors, bonnet and volumetric. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #763672 15th Mar 2019 5:48pm
