Home > Maintenance & Modifications > LOF POWERspring pedal assist |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5729 |
I want a lighter pedal than my standard due to driving different vehicles. I find it difficult to swap to something with a very light clutch after driving my Def all week, especially when I had the old straight spring on it.
9th Mar 2019 5:30pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4795 |
Royo would be interested to try this at the Easter meet if I may please........more expense coming 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
9th Mar 2019 7:57pm |
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 161 |
So all you guys who have fitted them; what’s the trick to making th e job easy...?
9th Mar 2019 8:54pm |
lordackers Member Since: 05 Dec 2018 Location: Leeds Posts: 47 |
Did mine this afternoon, got this from another site 😳 I used a vice to close the spring then two tie wraps one on each side on the straight bits to hold in place, with the pedal up align the two ends into the side bushes and was a then depress the clutch and secure with something I just used a piece of 3x2 cut to length wedged against the seat. align the closed end of the spring with the catch at the back of the pedal, then cut the tie wraps, I used a knife as I found the snips were awkward to get in. it’s important to get the back lined up as near as possible with the back bush, ideally within it otherwise it doesn’t locate properly and springs off,
Took me about 10 attempts but I reckon now I’ve done it, I could do it again first time The result? defiantlay less resistance, not massive but definitely easier, will know better on a longer run as was late for work so only had time to manoeuvre back onto the garage Edited to add pics, of the old spring but should give you an idea Click image to enlarge Click image to enlarge Click image to enlarge If I get everything done that I need to do today I’ll be amazed.... |
9th Mar 2019 10:19pm |
deaallen Member Since: 15 Feb 2016 Location: Basingstoke Posts: 264 |
I wish I had seen that way of fitting with the zip ties before messing around with mine! I'm slightly worried I may have deformed mine trying to get it in!
Does your have a sharp increase of resistance towards the "top" of the pedal press like mine? |
10th Mar 2019 10:26am |
Deaallen,
Not sure bud will let you know when I get chance for a decent test drive Cheers Ackers If I get everything done that I need to do today I’ll be amazed.... |
10th Mar 2019 10:51am |
Lwb97 Member Since: 10 Sep 2015 Location: Powys Posts: 75 |
Fitted mine today on my td5 replacing the lr spring. Definitely worth the money. Pressing the clutch pedal now is effortless. Very happy
10th Mar 2019 8:11pm |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
More than happy for you to have a go at the meet. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
10th Mar 2019 9:23pm |
Thanks Roy will be very interesting to feel how different it is 2015 HT XS 90
10th Mar 2019 9:33pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2178 |
Just fitted Lukes new spring. Its brilliant.
I had the Britpart one in before to replace the older top mounted spring, i was happy with that but bought the POWERspring on a punt, differencd is even more! The weight reduction is as advertised! So much lighter now! I would suggest it!! Instagram @defender_ventures Empire Tuning - Agent |
14th Mar 2019 9:54pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3683 |
10 minutes to fit is utter horse sh*t! Been at it for an hour and not further on. Any hints?!
16th Mar 2019 1:36pm |
Sorted. Brute force and ignorance won the day.
16th Mar 2019 2:19pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5111 |
Love your carpentry skills Co1 and choice of timbers as per the photos on your Instagram account For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
16th Mar 2019 3:13pm |
Thanks Gilarion, much appreciated.
16th Mar 2019 3:15pm |
