Home > Maintenance & Modifications > Best DAB Ariel?
Page 2 of 2 <12
Emptywallet
United Kingdom 2005 Defender 110 Td5 CSW Tonga Green
I have a Kinetic DEGA-T4002 telescopic DAB glass mount aerial fixed to the top left corner of my windscreen. It is absolutely superb. I manage to get a signal in many places the factory fit DAB aerials in my other cars can’t. It was a doddle to fit too and after 10 months fitted there is no sign of the adhesive on either side of the glass letting go.
I got from a company called dabonwheels.
Post #762585 8th Mar 2019 8:07pm
PCM
Do you have a pic of it fitted as this may be just the job.
Cheers Thumbs Up
Post #762603 8th Mar 2019 9:27pm
Tegner
United Kingdom 2010 Defender 90 Puma 2.4 HT Zermatt Silver
I've had one of these fitted for over a year great signal even in remote areas beats my Audi hands down. this one has GPS as my unit has sat nav but they done with just FM/DAB it needs a 12v supply
http://www.connects2.co.uk/Product/ProductItem/CT27UV56
without GPS
http://www.connects2.co.uk/Product/ProductItem/CT27UV53
Post #762784 10th Mar 2019 2:21pm
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
I also get interference when I put the lights on spoke to a ICE man in Harlow on Saturday he told me he's done loads of Defenders and fits a VW aerial and that works so booked in to have this fitted next week, fingers crossed this will work.
Post #762792 10th Mar 2019 3:20pm
Emptywallet
Here you go.
Post #762810 10th Mar 2019 5:22pm
Emptywallet
Here you go.
Post #762812 10th Mar 2019 5:31pm
PCM
OK Problem solved.
The DAB tuner on certain kenwood and JVC models has an inherant fault in them. Swapped to a poineer in the workshop and worked fine. Will put a post in about the models affected but itæs the ones that are half defth (Not standard depth)
The models affected are the JVC KW-M745DBT sold on Mudstuff and the Kenwood DMX7018
The full depth models such as the kenwood DMX7017 are ok.
I've also tested 4 types of car airiel before swapping the head unit and the best one by far for reception is the opriginal vehicle one. Go figure.
he is no interference from the bluesea USB.
Have an official reply from Kenwood to clarify. Next batch of units will be redesigned and will be available in June/July
Post #764813 22nd Mar 2019 11:27am
foxhound
United Kingdom 1995 Defender 110 300 Tdi SW Alpine White
PCM wrote:
I must live in a rubbish signal area as the town centre is fine, but near my house is just awful.
Only concern is all other cars work great.
Mine can’t get anything but static on dab and FM.
Anyone used the nakatanakaka..... one?
I have the Naka antenna, and a splitter box so it picks up DAB and FM. It's very good (though if I use one of my 4 usb sockets on the dash, the DAB is lost and the FM turns to mush but i'm sure that's a wiring problem not a Naka problem (just can't find the solution yet!) 110 Defender 300tdi & Penman trailer with ally exped top and roof tent
Post #769722 23rd Apr 2019 3:08pm
Page 2 of 2 <12
