![]() | Home > Puma (Tdci) > Oil filter cap key dimension |
Who remember the dimension (mm?) of the hexagon key for the oil filter cap??
Thank you Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 ![]() ![]() ![]() |
27mm is a perfect tight fit
![]() 98 V8 Disco |
You are the man!!! Thank you M8 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
Same as the wheelnut key... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
