Home > Puma (Tdci) > Oil filter cap key dimension |
Who remember the dimension (mm?) of the hexagon key for the oil filter cap??
Thank you Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
17th May 2011 1:17pm |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 |
27mm is a perfect tight fit 130 crew cab
98 V8 Disco |
17th May 2011 3:49pm |
You are the man!!! Thank you M8 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
17th May 2011 4:45pm |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
Same as the wheelnut key... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
17th May 2011 6:00pm |
