Home > In Car Electronics > Nakatanenga DAB antenna
Page 8 of 8 <12345678
topigo
It not work. I try to disconnect from power without antenna and issue is same, touch is not working on dab.
If youtube links not allowed, please remove.
Post #1064322 31st Mar 2025 5:17pm
defenderfraggle
Netherlands 2009 Defender 130 Puma 2.4 HCPU Santorini Black
I have/had the same error on a more simple kenwood device and there in the tuner settings I needed to disable (off) the power to the antenna.
Then the error disappears.
Problem is that the stupid radio does not rememen=ber although there is a normal power feed to the radio. It does remember last settings and memory. But it Dows not remember NOT to power the antenna :-/
Regards, hope it works for you.
Jan
Post #1064347 31st Mar 2025 9:08pm
