Home > Puma (Tdci) > central lock |
Maxer Member Since: 24 Jan 2016 Location: Mazovia forest Posts: 4 |
Hello, I have a bad experience with the central locking on my 110 Defender (2015). When the frost comes (temperature minus zero after a rainy weather) it is impossible to open the central lock. When I try to open lock (using the remote pilot) the door locking pin opens and immediately close – then runs periodicaly (open and close continually about 1 s).
I suppose that the cause of such a behavior is ice located on sensor (open/close door) which wrongly informs the central locking unit of the actual state. Have you got a similar experience ? Best regards, Piotr |
12th Jan 2019 9:13pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3287 |
I experienced the same a couple of weeks back. Managed to get in the passenger side. Hasn't happened since.
12th Jan 2019 9:16pm |
RockfieldWines Member Since: 13 Feb 2014 Location: Monmouth Posts: 29 |
I have had a recurring battle with the central locking on my 2007 DCpU. No spine is one problem fixed then another part sticks jams or falls off. I’ve just put a steering lock on and stopped locking the doors!
25th Jan 2019 12:48pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 735 |
I've experienced that if the power lock functions properly, all is well. But once power lock becomes intermittent or temporarily disabled, locking one or two doors by hand becomes impossible. Why is this? Do I need to adjust something?
26th Jan 2019 5:43am |
