Home > Puma (Tdci) > central lock
Maxer
Poland
central lock
Hello, I have a bad experience with the central locking on my 110 Defender (2015). When the frost comes (temperature minus zero after a rainy weather) it is impossible to open the central lock. When I try to open lock (using the remote pilot) the door locking pin opens and immediately close – then runs periodicaly (open and close continually about 1 s).
I suppose that the cause of such a behavior is ice located on sensor (open/close door) which wrongly informs the central locking unit of the actual state.
Have you got a similar experience ?
Best regards,
Piotr
Post #750811 12th Jan 2019 9:13pm
Zed
I experienced the same a couple of weeks back. Managed to get in the passenger side. Hasn't happened since.
Post #750815 12th Jan 2019 9:16pm
hornet
Re: central lock
Piotr
This is due to the "toughness" of the opening mechanism caused by the cold. Because it does not fully open, it is immediately closed again. The only remedy is to clean and lubricate all moving parts freshly.
You can (temporarily) also program the 10AS into a pure central locking unit via nanocom and then at least handle with key without the alarm going off. But no idea what has to be done on models that do not have the 10AS -- like yours.
Post #751416 15th Jan 2019 11:40am
RockfieldWines
Wales 2007 Defender 110 Puma 2.4 DCPU Baltic Blue
I have had a recurring battle with the central locking on my 2007 DCpU. No spine is one problem fixed then another part sticks jams or falls off. I’ve just put a steering lock on and stopped locking the doors!
Post #753863 25th Jan 2019 12:48pm
HardCharger
I've experienced that if the power lock functions properly, all is well. But once power lock becomes intermittent or temporarily disabled, locking one or two doors by hand becomes impossible. Why is this? Do I need to adjust something?
Post #753984 26th Jan 2019 5:43am
