Home > Td5 > TD5 Driver Demand
Page 3 of 5 <12345>
bankz5152
It can happen. Rare but it can. Happened on my 90 after some lanes, would just suddenly loose power and or go into limp mode. On a whim i changed the sensor never had an issue 2 years later.
Post #749549 6th Jan 2019 12:27pm
kevinp
England 1999 Defender 90 Td5 HT Rutland Red
had a similar problem on mine would just go to limp mode then clear or would suddenly give me a really lazy throttle after months of looking bought a hawkeye and watched sensors when it happened found it was temp side of map sensor limp mode it would jump from 28 degress to 136 then would drop back to 28 and run fine and if it went the other way -35 lazy throttle ,new sensor sorted
Post #749863 8th Jan 2019 7:09am
TJ101
Thanks guys... Not had a chance to look at it as yet,, will be weekend at the earliest,, Autosport show from Thursday on
Ordered a genuine Map sensor,
Plus a good friend, Thumbs Up is sending me a Nanocom down, see if that gives any more info, over the Snap-on unit California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #749998 8th Jan 2019 3:49pm
dkmlondon
United Kingdom 2006 Defender 110 Td5 XS CSW Cairns Blue
Hi TJ101
Reading your thread with interest.
Have an occasional starting issue on my Td5 110 CSW MY2006, when cold, with the well-reported chugging and no pick-up.
Injector seals done,
MAF new,
ECU wiring clear,
EGR removed,
decent map (Stage 2 by JE Engineering) with uprated cooler
quiet fuel pump etc etc
but she will still protest when cold (like the rest of the family!) but eventually agrees to participate.
Am living with it pro tem, but would love a solution!
Other reason for post is to offer use of my Nanocom - am not far from Taunton, and always good to share one's weaknesses and addictions! It is a really useful addition.
PM me if of any interest or your mate's doesn't arrive.
DM
Post #750394 10th Jan 2019 7:32pm
TJ101
Thanks DM
Been up at Autosport show all day, and see friends units has arrived, plus a gen Map sensor , Hopefully may get a chance to have a look tomorrow ? have a use for the 90 on Sunday Drive round day Smile
PS Welcome to the D2 forum Thumbs Up California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #750406 10th Jan 2019 8:10pm
dkmlondon
Many thanks for the welcome - have been a td5 owner for about 15 years, (and RRC many years ago when they were new...!) and am enjoying exploring the distant corners of Landy-lore as a newb!
Is there a Sunday Drive in Somerset?
Post #750418 10th Jan 2019 8:27pm
TJ101
Next event that your 110 will be ok with is
https://www.defender2.net/forum/topic65403.html
A 110, on Sundays Drd,, even though they have been round before would not be ideal
https://www.4x4adventures.co.uk/_main/drive_round_days.htm California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #750425 10th Jan 2019 8:51pm
dkmlondon
At the risk of heading off topic Off Topic that could work well. Might get swmbo to come along in her Disco sport too, if that isn't too frightful! She has often expressed a wish to explore it's capacity for nonsense!
Will enter negotiations and respond via website.
Many thanks for the steer. Thumbs Up
Post #750454 10th Jan 2019 9:49pm
TJ101
Update
Well, 3rd trip out on a Drive round day,, 3rd time it played up,,
Mil light on, and no throttle,switch off and restart ok,but same misfire, and non driveability
Fitted a new gen Map sensor there and then made no difference,
checked live values via nanacom,, all looked ok, certainly the pedal values
Earthing points next call ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #751333 14th Jan 2019 10:36pm
landy andy
Wasn’t there an issue with earth to the fuses, and relays under driver seat that caused problems in the past?
Think it always made the temp gauge shoot up thpugh, and you’d have noticed that.
Post #751338 14th Jan 2019 10:49pm
TJ101
Hi Andy
Temp gauge is working, and tests ok, via Nanacom
Could be a coincidence , when it played up yesterday, i noticed the difflock light on 3rd brightness ? hence thinking earths ?
saying that, the light did then come on as it should, but problem still there
So,, start in fusebox !, fault is so intermittent,, was fine driving to the venue, and for the first hour or so,, then limp all the way home !!! looking for all the downhill bits, Mil light coing on quite often, needed a rolling switch off and restart Shocked California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #751347 14th Jan 2019 11:30pm
bankz5152
Upsetting!
Tried the crank sensor?
Post #751358 15th Jan 2019 6:20am
landy andy
If you do swap/check the crank sensor look for the spacer that might be there or damage to the end of the sensor due to spacer being required.
I don’t know why some need spacer and others don’t.
Post #751626 16th Jan 2019 8:57am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Bad engine ECU - I have repaired domě TD5 ECUs with blown components in crank sensor circuit. Domě tiny parts were broken. All cars had problems with crank sensor signal, all had tried new sensor s and spacers. Car were tuning, but not optimal. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #751695 16th Jan 2019 2:12pm
jst
dont forget the DRL flicker when you winch too, also links to earthing? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #751794 16th Jan 2019 9:29pm
Page 3 of 5 <12345>
