Home > Technical > 200tdi Disco 1 suddenly stopped
Page 2 of 2 <12
dioliahary
I am wondering that if the injectors were sludged and when they were tested that the sludge cleared up...maybe that could be the problem (wishful thinking at this point, you could not get a more simple reliable engine than the 200tdi!) 1990 200tdi conversion 90
Post #746565 20th Dec 2018 8:23am
dioliahary
Some feedback, I have removed the timing case and the belt has failed, it looks like it was rubbing on the case cover. I changed the belt around 100 or so mile ago and the belt that I removed was in perfect condition. So I am assuming that it must be something I have done. Has anyone come across this before, I have a new belt and luckily enough there seems to be no permanent damage, going to get my mate (x taxi mechanic) to oversee the fitting of the replacement.
Post #747741 28th Dec 2018 3:10pm
OJ
Scotland 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Looking at your crank pulley, is there not a modified one with a flange to help keep the belt from sliding forward. Comes as part of the belt kit from Britpart. Lucky your engine survived Thumbs Up
See pic
Post #748511 1st Jan 2019 4:46pm
htb2
Wales
I didn't know there was a modified pulley for the 200tdi, none of mine have had it, over the last 20 yrs
Post #748513 1st Jan 2019 4:51pm
dioliahary
I am not sure but think the modified pulley is for the 300tdi.
I believe that I must have set it up incorrectly. 1990 200tdi conversion 90
Post #748550 1st Jan 2019 8:17pm
OJ
You may be right it was a 300 i did recently,
Post #748581 1st Jan 2019 9:21pm
OJ
Might just be the 300, i thought it was both 200 and 300 but might be wrong.
OJ
Post #748582 1st Jan 2019 9:27pm
VVS210
Looking at your photos there seems to be no tension in the belt between the tensioner & the fuel pump pulley & it looks like the belt is running over the casting for the bolt hole at the 5 o'clock position on the fuel pump pulley. My guess would be you have not set the tensioner up correctly.
Post #748589 1st Jan 2019 9:50pm
dioliahary
Fitted the belt today, my mate did it ( he has done hundreds x taxi mechanic). Quick question the belt seems to overhang the FIP gear by about a millimetre and runs tight against the radiator side of the tension pulley. Should I be worried about this? Btw my pal is really happy with it and I trust him, but I am verging paranoid after it failed.
Post #749425 5th Jan 2019 6:23pm
Looks about right to me... the flange on the other gear will keep the belt in "place" so to speak, so should be ok.
Post #749446 5th Jan 2019 7:41pm
OJ
Good you got it sorted Thumbs Up
Post #749473 5th Jan 2019 9:01pm
dioliahary
Putting it back together decided to give it a lick of paint 1990 200tdi conversion 90
Post #749556 6th Jan 2019 1:45pm
dioliahary
Bit of advice needed, all back together, Rev up and lots of white smoke then cuts out, tickover is fine but every now and then sounds like it misses a bit🤔
One thing noticed that the low pressure fuel supply to the lift pump will not seal ( due to shoddy new lift pump) would this factor in the fault. 1990 200tdi conversion 90
Post #752377 19th Jan 2019 3:31pm
Page 2 of 2 <12
