![]() | Home > Technical > 200tdi Disco 1 suddenly stopped |
dioliahary Member Since: 18 Jan 2015 Location: Manchester Posts: 668 ![]() ![]() |
Some feedback, I have removed the timing case and the belt has failed, it looks like it was rubbing on the case cover. I changed the belt around 100 or so mile ago and the belt that I removed was in perfect condition. So I am assuming that it must be something I have done. Has anyone come across this before, I have a new belt and luckily enough there seems to be no permanent damage, going to get my mate (x taxi mechanic) to oversee the fitting of the replacement.
![]() Click image to enlarge ![]() Click image to enlarge 1990 200tdi conversion 90 |
OJ Member Since: 23 Nov 2018 Location: North of Edinburgh Posts: 121 ![]() ![]() ![]() |
Looking at your crank pulley, is there not a modified one with a flange to help keep the belt from sliding forward. Comes as part of the belt kit from Britpart. Lucky your engine survived
![]() See pic ![]() |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 536 ![]() ![]() |
I didn't know there was a modified pulley for the 200tdi, none of mine have had it, over the last 20 yrs
I am not sure but think the modified pulley is for the 300tdi.
I believe that I must have set it up incorrectly. 1990 200tdi conversion 90 |
You may be right it was a 300 i did recently,
Might just be the 300, i thought it was both 200 and 300 but might be wrong. Cheers OJ |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 ![]() ![]() |
Looking at your photos there seems to be no tension in the belt between the tensioner & the fuel pump pulley & it looks like the belt is running over the casting for the bolt hole at the 5 o'clock position on the fuel pump pulley. My guess would be you have not set the tensioner up correctly.
Fitted the belt today, my mate did it ( he has done hundreds x taxi mechanic). Quick question the belt seems to overhang the FIP gear by about a millimetre and runs tight against the radiator side of the tension pulley. Should I be worried about this? Btw my pal is really happy with it and I trust him, but I am verging paranoid after it failed.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 1990 200tdi conversion 90 |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6119 ![]() ![]() ![]() |
Looks about right to me... the flange on the other gear will keep the belt in "place" so to speak, so should be ok.
Good you got it sorted
![]() Click image to enlarge ![]() Click image to enlarge Putting it back together decided to give it a lick of paint 1990 200tdi conversion 90 |
Bit of advice needed, all back together, Rev up and lots of white smoke then cuts out, tickover is fine but every now and then sounds like it misses a bit🤔
One thing noticed that the low pressure fuel supply to the lift pump will not seal ( due to shoddy new lift pump) would this factor in the fault. 1990 200tdi conversion 90 |
