Home > Technical > Exhaust - blue smoke
ericvv
Yesterday morning has a short occurrence of thick blue smoke from the exhaust. Here is the situation.
Early morning ambient temp here was -3°C. Truck had been parked for a few days under the carport.
When starting, I had the usual puff of a bit of blue smoke which normally is a matter of seconds only.
This time a bit different. I started driving about immediately from cold but without much rpm and without asking any real effort to speak of on the engine.
From our house it is merely 50 meter flat until there is a 100 meter long stretch of really steep downhill to the main road.
As usual I went downhill in first, no gas at all, but using the engine brake making sure engine does not go above 2000 rpm.
Here comes my surprise. I always thought when using engine brake, fuel supply is cut off. But the entire 100 meter downward stretch during engine braking I got pretty thick blue smoke all the way.
Carefully continued on the main road with minor engine load, and after 2/300 meter only, the blue smoke disappeared and turned normal white as normal when it is this cold.
We then did a normal highway and city trip, everything just normal. The entire time, including from the cold start, the engine turned round just normally, also no strange sounds.
Any idea what could have caused that short event of thick blue smoke?
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #745985 16th Dec 2018 1:27pm
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
interesting... I had and have some bluish smoke from my td5 110, when posted on social media and then spoke with my garage, they said all was ok.. and just lately with the cold weather I do seem to notice it a bit more.. be interesting to see what comes up this time round. Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #745995 16th Dec 2018 2:23pm
MK
Most of the time blue smoke is related to oil into the combustion chamber. Just google the subject and you will have lots of info whether to blame valve stem seals, worn rings-cylinder etc. Puma 110" SW
Post #745998 16th Dec 2018 2:27pm
ericvv
Thanks for the pointers. Just gave it another try from cold again. This time just a few seconds of blue-ish smoke (has always done that), and then it turned quickly back to white/colourless, also on the same steep downhill stretch as yesterday. Oil level also at the full mark, so not sure what to make of it. Yesterday the blue smoke was much thicker than today. Guess will just be attentive to it for now.
Post #746004 16th Dec 2018 3:06pm
Norton
United Kingdom 1990 Defender 90 2.5 n/a Diesel ST Nato Green
Look on the bright side. At least it is starting and running!!!
Post #746006 16th Dec 2018 3:08pm
Adam17
Eric
Is it possible to video it next time??
Im not even sure if videos can be uploaded, but have seen videos on here... Regards
Adam
Loving The Duchess
Post #746018 16th Dec 2018 3:45pm
ericvv
Question. Is a puff of blue tinted smoke for just a few seconds at startup normal? I thought it was, but on condition that it turns to transparant/whitish within 2 or 3 seconds. Right or wrong?
Post #746032 16th Dec 2018 5:15pm
MK
That points to valve stem seals. But I probably would not worry about it.
In warmer weather you could leave it for 1 hour after reaching normal operating temperature and start it again and see what happens. Puma 110" SW
Post #746041 16th Dec 2018 5:53pm
Dieseljock
Scotland 2003 Defender 90 Td5 HT Zambezi Silver
Is it a TD5, as mines does this from cold especially on a downhill. Was told it was possibly to do with injector lash settings. It does smell like unburnt fuel. Like an injectior sticking when cold, used to see it at work quite often with Perkins and cummins engines.
Post #746052 16th Dec 2018 7:43pm
ericvv
It’s a 2008 Puma Td4, 2.4 liter. As today it didn’t do it again, can only hope it was a one-off, and maybe the sticking valve suggestion could well have been the culprit. Will surely monitor it closely.
Out of curiosity, do others with a Puma have a brief puff of blueish smoke at a cold start, just for a few seconds?
As said, mine has done that for as long as I can remember, so maybe that is just normal. Obviously the big blue smoke of yesterday as explained was not normal.
Contrary to many on here, my main dealer here in Geneva are very good. Will also ask them about it.
Post #746054 16th Dec 2018 8:03pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
when cold mine has grey / white smoke for about 1/2 mile then clear.
BTW- td5 with 115k on the clock.
Pulls well, sounds good and I do not worry about it Thumbs Up
Post #746056 16th Dec 2018 8:07pm
Grenadier
Obviously getting similar weather to you Eric. Only when cold I get a big belch of blue/grey, then after a few seconds it turns to white which stays until we hit the main road, approx 750m downhill so very little revs over that distance. All gone by the time I’m using normal revs. I can say it does smell a bit though.
This has been the same the last two winter seasons, albeit the belch of blue grey seems to have got a bit bigger. Shocked Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #746109 17th Dec 2018 9:56am
LR90XS2011
I think you are worrying too much, probably just cold related or a glug of oily muck from the inlet tract / crankcase breather system. DEFENDER 90 TDCI XS,
Post #746186 17th Dec 2018 8:38pm
ericvv
Post #746246 18th Dec 2018 7:09am
jst
If I don't use the ashes to to prewarn my 2010 24 i get white smoke on initial startup only. No blue.
If it did it after a few days standing but doesn't do it after say 24hrs quite as bad it would suggest something leaking into combustion chamber over time there is a greater build up.
What's it like if left e days? If possible ? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #746248 18th Dec 2018 7:49am
