Home > Technical > Exhaust - blue smoke |
Yesterday morning has a short occurrence of thick blue smoke from the exhaust. Here is the situation.
Early morning ambient temp here was -3°C. Truck had been parked for a few days under the carport. When starting, I had the usual puff of a bit of blue smoke which normally is a matter of seconds only. This time a bit different. I started driving about immediately from cold but without much rpm and without asking any real effort to speak of on the engine. From our house it is merely 50 meter flat until there is a 100 meter long stretch of really steep downhill to the main road. As usual I went downhill in first, no gas at all, but using the engine brake making sure engine does not go above 2000 rpm. Here comes my surprise. I always thought when using engine brake, fuel supply is cut off. But the entire 100 meter downward stretch during engine braking I got pretty thick blue smoke all the way. Carefully continued on the main road with minor engine load, and after 2/300 meter only, the blue smoke disappeared and turned normal white as normal when it is this cold. We then did a normal highway and city trip, everything just normal. The entire time, including from the cold start, the engine turned round just normally, also no strange sounds. Any idea what could have caused that short event of thick blue smoke? Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
16th Dec 2018 12:27pm |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 |
interesting... I had and have some bluish smoke from my td5 110, when posted on social media and then spoke with my garage, they said all was ok.. and just lately with the cold weather I do seem to notice it a bit more.. be interesting to see what comes up this time round. Regards
Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
16th Dec 2018 1:23pm |
Thanks for the pointers. Just gave it another try from cold again. This time just a few seconds of blue-ish smoke (has always done that), and then it turned quickly back to white/colourless, also on the same steep downhill stretch as yesterday. Oil level also at the full mark, so not sure what to make of it. Yesterday the blue smoke was much thicker than today. Guess will just be attentive to it for now.
16th Dec 2018 2:06pm |
Norton Member Since: 10 Sep 2018 Location: Buckinghamshire Posts: 28 |
Look on the bright side. At least it is starting and running!!!
16th Dec 2018 2:08pm |
Is it possible to video it next time?? Im not even sure if videos can be uploaded, but have seen videos on here... Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
16th Dec 2018 2:45pm |
Question. Is a puff of blue tinted smoke for just a few seconds at startup normal? I thought it was, but on condition that it turns to transparant/whitish within 2 or 3 seconds. Right or wrong?
16th Dec 2018 4:15pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2446 |
That points to valve stem seals. But I probably would not worry about it.
In warmer weather you could leave it for 1 hour after reaching normal operating temperature and start it again and see what happens. Puma 110" SW ............................................................. Earth first. Other planets later |
16th Dec 2018 4:53pm |
Dieseljock Member Since: 03 Jun 2017 Location: Inverclyde Posts: 32 |
Is it a TD5, as mines does this from cold especially on a downhill. Was told it was possibly to do with injector lash settings. It does smell like unburnt fuel. Like an injectior sticking when cold, used to see it at work quite often with Perkins and cummins engines.
16th Dec 2018 6:43pm |
It’s a 2008 Puma Td4, 2.4 liter. As today it didn’t do it again, can only hope it was a one-off, and maybe the sticking valve suggestion could well have been the culprit. Will surely monitor it closely.
Out of curiosity, do others with a Puma have a brief puff of blueish smoke at a cold start, just for a few seconds? As said, mine has done that for as long as I can remember, so maybe that is just normal. Obviously the big blue smoke of yesterday as explained was not normal. Contrary to many on here, my main dealer here in Geneva are very good. Will also ask them about it. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
16th Dec 2018 7:03pm |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
when cold mine has grey / white smoke for about 1/2 mile then clear.
BTW- td5 with 115k on the clock. Pulls well, sounds good and I do not worry about it |
16th Dec 2018 7:07pm |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5878 |
Obviously getting similar weather to you Eric. Only when cold I get a big belch of blue/grey, then after a few seconds it turns to white which stays until we hit the main road, approx 750m downhill so very little revs over that distance. All gone by the time I’m using normal revs. I can say it does smell a bit though.
This has been the same the last two winter seasons, albeit the belch of blue grey seems to have got a bit bigger. Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
17th Dec 2018 8:56am |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3650 |
I think you are worrying too much, probably just cold related or a glug of oily muck from the inlet tract / crankcase breather system. DEFENDER 90 TDCI XS,
17th Dec 2018 7:38pm |
^^ Hope you are right. So far it proved a one-off event, so just will watch it.
18th Dec 2018 6:09am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8152 |
If I don't use the ashes to to prewarn my 2010 24 i get white smoke on initial startup only. No blue.
If it did it after a few days standing but doesn't do it after say 24hrs quite as bad it would suggest something leaking into combustion chamber over time there is a greater build up. What's it like if left e days? If possible ? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
18th Dec 2018 6:49am |
