Home > Technical > 2013 110 Puma - clunk noise from rear
Page 1 of 4 1234>
Tumbiri
2013 Defender 110 Puma 2.2 XS CSW Orkney Grey
Braking normally to a stop while going down hill, parking brake set, foot brake release. vehicle rocks forward, clunk noise somewhere in the rear. Happens only once, i.e. if I repeat the process immediately afterwards there is no clunk. Happens when stopping going up hill as well. This started after the rear axle was replaced. On inspection, nothing obvious. Any ideas what could be causing this?
Post #745625 14th Dec 2018 12:13am
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Have you checked your drive flanges? Common cause for driveline clunk.
Post #745630 14th Dec 2018 12:58am
Tumbiri
Not sure what you mean by drive flanges.
Post #745632 14th Dec 2018 1:21am
WindyJ
The star shaped piece with 5 bolts in center of wheel. Take rubber cap off and check for play with wheel off ground. Should be no movememnt on the splines.
Just changed to Ashcroft HD ones myself, a 10mn job no more difficult than taking wheel off (which you do not have to do). Clucking vanished.
Post #745637 14th Dec 2018 6:08am
LR90XS2011
if you have alloys you do need to remove the wheels, these flanges are really a service item, grease from new and then check every 20000 miles or so, expect to replace when wear occurs. and dont forget to do the front as well DEFENDER 90 TDCI XS,
Post #745640 14th Dec 2018 7:53am
WindyJ
Or remove the inner seal and let the diff oil do the job it should be doing.
Post #745643 14th Dec 2018 8:49am
Tumbiri
Thanks people, will give it a go.
Post #745665 14th Dec 2018 12:24pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
I've squirted motorcycle chain lube into my flanges under the rubber caps. It flows in very easily and then partially solidifies as the solvent evaporates off. Goodness knows if it will prevent the wear, but I'm hoping it might help slow it down a bit.
Post #745678 14th Dec 2018 3:59pm
Bluest
Again, who knows if it helps, but I use moly grease on my flanges ( Shocked ) as it is supposed to be good for protecting sliding surfaces. At the end of the day, any lubricant is better than leaving it dry. 2007 110 TDCi Station Wagon XS
Post #745681 14th Dec 2018 4:29pm
Another possible source of the clunk you describe is the A frame ball joint.
I've got one piece half shafts on mine but it's recently developed a very similar sounding clunk and that's my prime suspect. Darren
Post #745686 14th Dec 2018 5:01pm
SimonDavies
Wales 2010 Defender 90 Puma 2.4 HT Zambezi Silver
If it only occurs when putting the park brake on, I would jack a rear wheel and check for any grabbing on the park brake drum to rule that out (with park brake released.
Apply park brake, the drum should be locked solid. Move the prop to check for any play in the driveline and narrow it down from there.
Post #745714 14th Dec 2018 7:14pm
landy andy
I had this on my Tdci. It was the drive flange on the diff.
Post #745716 14th Dec 2018 7:29pm
oneten110
Later models have one piece half shafts, don't they?
Post #745743 14th Dec 2018 10:04pm
Only from about 2015 as standard. Darren
Post #745750 14th Dec 2018 11:01pm
Tumbiri
A-Frame ball joint was replaced at the same time as the axle so I don't think that is the cause. Will check for parking brake grabbing. Thanks to all.
Post #745762 15th Dec 2018 12:31am
Page 1 of 4 1234>
