![]() | Home > Technical > 2013 110 Puma - clunk noise from rear |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 432 ![]() ![]() ![]() |
Have you checked your drive flanges? Common cause for driveline clunk.
Tumbiri Member Since: 01 Nov 2016 Location: Caribbean Posts: 52 ![]() ![]() |
Not sure what you mean by drive flanges.
WindyJ Member Since: 18 Oct 2018 Location: France Posts: 190 ![]() |
The star shaped piece with 5 bolts in center of wheel. Take rubber cap off and check for play with wheel off ground. Should be no movememnt on the splines. Just changed to Ashcroft HD ones myself, a 10mn job no more difficult than taking wheel off (which you do not have to do). Clucking vanished. |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3663 ![]() ![]() ![]() |
if you have alloys you do need to remove the wheels, these flanges are really a service item, grease from new and then check every 20000 miles or so, expect to replace when wear occurs. and dont forget to do the front as well DEFENDER 90 TDCI XS,
Or remove the inner seal and let the diff oil do the job it should be doing.
Thanks people, will give it a go.
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
I've squirted motorcycle chain lube into my flanges under the rubber caps. It flows in very easily and then partially solidifies as the solvent evaporates off. Goodness knows if it will prevent the wear, but I'm hoping it might help slow it down a bit.
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4255 ![]() ![]() ![]() |
Again, who knows if it helps, but I use moly grease on my flanges (
Another possible source of the clunk you describe is the A frame ball joint.
I've got one piece half shafts on mine but it's recently developed a very similar sounding clunk and that's my prime suspect. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
SimonDavies Member Since: 15 Mar 2012 Location: Swansea Posts: 244 ![]() ![]() ![]() |
If it only occurs when putting the park brake on, I would jack a rear wheel and check for any grabbing on the park brake drum to rule that out (with park brake released.
Apply park brake, the drum should be locked solid. Move the prop to check for any play in the driveline and narrow it down from there. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5855 ![]() ![]() |
I had this on my Tdci. It was the drive flange on the diff.
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 ![]() ![]() |
Later models have one piece half shafts, don't they? |
Only from about 2015 as standard. Darren
A-Frame ball joint was replaced at the same time as the axle so I don't think that is the cause. Will check for parking brake grabbing. Thanks to all.
