Home > Maintenance & Modifications > Reversing Light
Sammyboy
United Kingdom 2012 Defender 110 Puma 2.2 USW Sumatra Black
Reversing Light
As we all know the reversing light is not that bright or effective. I am looking for any ideas to upgrade and improve its effectiveness. Either a more powerful light unit or an additional light unit (work lamp??). Wiring suggestions would also be appreciated. I currently have a Wipac LED reversing light. Bow down Discovery 4 HSE
Defender 2.2 110 USW XS
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #742090 24th Nov 2018 11:03pm
Romadog
Put another on the other side aswell Thumbs Up
Post #742091 24th Nov 2018 11:06pm
grafty99
Twin reverse is the way to go, may as well do fog whilst you're at it Whistle (I may be biased Laughing )
 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #742094 24th Nov 2018 11:51pm
Sammyboy
Looks good. Thumbs Up Are those both standard reversing lights or are they upgraded to a brighter output? Discovery 4 HSE
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #742096 25th Nov 2018 12:16am
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
I installed a work light on a far-corners LED numberplaye light (which has a mounting hole in it) then just wired it to the reverse light.
 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #742125 25th Nov 2018 10:13am
grafty99
They're genuine LED reversing lights as found on limited edition models (made by Perei) 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #742128 25th Nov 2018 10:37am
ARC99
I have done the same thing on mine except I have the Fog lights on the outside and the reverse on the inside as something was nagging me that the fog light had to be that way this http://www.legislation.gov.uk/uksi/1989/1796/schedule/11/made is all I could find on the subject so I presume it dose not matter which way round they are. Don't make old people mad.
Richard
Post #742129 25th Nov 2018 10:45am
grafty99
It shouldn't matter, I put the reverse lights closest to the outside as I wanted the corners of the vehicle to get the most illumination for reversing Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #742132 25th Nov 2018 11:43am
Horneteer
United Kingdom 1986 Defender 90 200 Tdi SW Firenze Red
I didn't have space for a triple mount as it would foul the wheel carrier, so used the KBX twins.
As the fog light isn't used very often I kept to one and moved it to below the bumperette.
Post #742238 25th Nov 2018 9:50pm
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
I have a Labcraft Compact LED and very happy with it.
Post #742266 26th Nov 2018 12:12am
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
I upgraded to a wipack led light, it's brighter, but not bright enough.. I thought about getting a light bar on the back, that can double up as a camping light, and and extra reverse light.
But I like the idea of above 👆 Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #742286 26th Nov 2018 7:44am
Litch
Had the twin NAS set-up on my 90 since 2001 and they were a definite improvement on the standard light but back in 2009 I replaced them all with Le Perei LED and the output is even better, I have no problems seeing what is behind, even on dark, wet nights.
 ONE LIFE, GET IT!
Post #742327 26th Nov 2018 1:10pm
Adam17
That's a lovely looking truck.
Might you be able to post a pic of the lights on in the eve?
Id be interested in getting a set.. and how did you piggy back the wire to the second light? and how did you trail the cable, above and around the door or under the door? Regards
Adam
Loving The Duchess
Post #742329 26th Nov 2018 1:25pm
kzycnn
Haven't used them myself as I have twin work lights on the back that I manually switch on when needed, but they might be worth a punt...
https://www.powerfuluk.com/vehicles/land-r...c-led.html
Came across them when looking for LED headlamps.
Tony
Post #742504 27th Nov 2018 1:26pm
Adam17
That looks ok don't it... But I like the idea of work lights better I think, dual purpose then,, I can use them when camping. Regards
Adam
Loving The Duchess
Post #742517 27th Nov 2018 3:11pm
