![]() | Home > Maintenance & Modifications > Reversing Light |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
Put another on the other side aswell
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
Twin reverse is the way to go, may as well do fog whilst you're at it
![]() ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Sammyboy Member Since: 28 Feb 2017 Location: Hampshire Posts: 121 ![]() ![]() ![]() |
Looks good.
![]() Defender 2.2 110 USW XS Ford Kuga AWD Discovery 3 Range Rover P38 Discovery - 300 TDI Discovery - 200TDI |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
I installed a work light on a far-corners LED numberplaye light (which has a mounting hole in it) then just wired it to the reverse light.
![]() Click image to enlarge 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
They're genuine LED reversing lights as found on limited edition models (made by Perei) 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
I have done the same thing on mine except I have the Fog lights on the outside and the reverse on the inside as something was nagging me that the fog light had to be that way this http://www.legislation.gov.uk/uksi/1989/1796/schedule/11/made is all I could find on the subject so I presume it dose not matter which way round they are. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
It shouldn't matter, I put the reverse lights closest to the outside as I wanted the corners of the vehicle to get the most illumination for reversing
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Horneteer Member Since: 10 Feb 2015 Location: Cornwall Posts: 60 ![]() ![]() ![]() |
![]() Click image to enlarge I didn't have space for a triple mount as it would foul the wheel carrier, so used the KBX twins. As the fog light isn't used very often I kept to one and moved it to below the bumperette. |
legin Member Since: 22 Jul 2017 Location: Chelmsford Essex Posts: 1004 ![]() ![]() ![]() |
I have a Labcraft Compact LED and very happy with it.
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 ![]() ![]() ![]() |
I upgraded to a wipack led light, it's brighter, but not bright enough.. I thought about getting a light bar on the back, that can double up as a camping light, and and extra reverse light.
But I like the idea of above 👆 Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 765 ![]() ![]() |
Had the twin NAS set-up on my 90 since 2001 and they were a definite improvement on the standard light but back in 2009 I replaced them all with Le Perei LED and the output is even better, I have no problems seeing what is behind, even on dark, wet nights.
![]() Click image to enlarge ONE LIFE, GET IT! Last edited by Litch on 26th Nov 2018 7:31pm. Edited 1 time in total |
That's a lovely looking truck.
Might you be able to post a pic of the lights on in the eve? Id be interested in getting a set.. and how did you piggy back the wire to the second light? and how did you trail the cable, above and around the door or under the door? Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
kzycnn Member Since: 24 Apr 2009 Location: Northumberland Posts: 277 ![]() ![]() ![]() |
Haven't used them myself as I have twin work lights on the back that I manually switch on when needed, but they might be worth a punt...
https://www.powerfuluk.com/vehicles/land-r...c-led.html Came across them when looking for LED headlamps. Tony |
That looks ok don't it... But I like the idea of work lights better I think, dual purpose then,, I can use them when camping. Regards
