Home > Maintenance & Modifications > Wiper Advice for an amateur!
CBearRun
Scotland 2007 Defender 110 Puma 2.4 CSW Epsom Green
Hi all,
my first post on Defender2 and it is very necessary.
A while back my wipers started to stick a little but it wasnt any hassle but last night on my drive home in the rain, dark and on the motorway my wipers packed in altogether!
I want to try this repair myself as have looked at the various issues it could be and to save money.
Looking to hear what the more experienced think will be the issue. I know this wont be a clean and simple answer.
So my wipers will slightly move downwards when switched on but that is all, when I turn them on I can hear the motor running from the non-glovebox area so know it still runs.
Do you think this could be a park switch issue or perhaps need a new set of wheels for the wipers?
I am a novice to any car repairs but obviously want to learn to keep my landy running at its best. Biggest thing I have done so far was attach my rear ladder for my rack.
I drive a 2007 Defender 110 CSW got 81000 miles.
any help would be great!!
Post #739837 11th Nov 2018 1:35pm
WindyJ
First thing is to check the relay - it’s the central red one in the fuse box by your knee. That’s most likely the culprit. While you are at it swap for a VW99 relay, about £10 on eBay and one of the best upgrades you can make!
Post #739839 11th Nov 2018 1:49pm
CBearRun
Excellent WindyJ i'll start with that. Much easier that removing the dash!! if it isnt that i'll add the upgrade to the overall fix.
Thanks for the advice
Post #739842 11th Nov 2018 1:53pm
sfrankland
England 2009 Defender 110 Puma 2.4 USW Indus Silver
I was just wondering what makes this a good upgrade? I may do it myself and I’m always looking for ways to improve the defender
Post #739844 11th Nov 2018 1:59pm
Cupboard
It gives you variable speed intermittent wipers.
Post #739845 11th Nov 2018 2:06pm
The VW99 relay gives you a variable intermittent wipe function. Darren
Post #739848 11th Nov 2018 2:08pm
sfrankland
Ah i see. so i guess i would need to change the wiper stork to be able to change the speed?
Post #739850 11th Nov 2018 2:10pm
No, the function is entirely within the relay. Here you go, have a read of this:
https://www.defender2.net/forum/topic6205.html?highlight=vw99 Darren
Post #739852 11th Nov 2018 2:13pm
landy andy
No, you use the same stalk. You just program the relay each time you use it.
Turn on intermittent wipers
They wipe
Turn off wipers, until enough rain on screen
They will now wipe at the time of the period that you had them off for in the above process
Post #739853 11th Nov 2018 2:14pm
sfrankland
Thats great thanks a lot for the link.
Post #739854 11th Nov 2018 2:16pm
sfrankland
They wipe
Excellent thanks for the advise. ill get one on order!
Post #739855 11th Nov 2018 2:16pm
WindyJ
It’s completely intuitive to use too....you won’t be trying to remember how it works or anything and you also get variable control of the wash wipe i.e. the longer you press squirt the longer the wipers stay on and vise versa, also water before wiper movement which is much better.
Post #739869 11th Nov 2018 3:38pm
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
It might be as "simple" as corrosion at the wiper arms. If you lift the rubber cover at the base of the wiper arms you can see the mechanism. You could well see rust at the shaft. Worth spraying a little WD40 onto the shaft, and wiggle the arms. This might free the mechanism. If it does, then after a few wipes you should properly lubricate with silicone spray lubricant. Don't forget to reseat the rubber seal.
Hope it is as simple as this. Otherwise a bigger job altogether. Plenty of threads on the site explain the bigger faults/repair.
Post #739874 11th Nov 2018 3:59pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
For both to stop working, I would think the issue is at the motor
I’ve just removed the dash on mine and you can see the motor on the left, the movable ‘chain’ sits within the silver tube that goes across the dash
The mechanism in the motor would be similar to a train steam engine wheel with rod attached and as the motor turns, the chain is pushed and pulled along the tube.
At 2 points the motor arms are attached to spindles which are attached to large perforated edged discs which catch the chain and thus cause the wipers to move back and forth.
It sounds like the chain has disconnected from the motor mechanism.
If it is this then it’s a partial dash removal if you can disconnect the chain from the motor...
if not the whole lot needs to come out Shocked
Welcome to owning a defender!
Post #739889 11th Nov 2018 5:18pm
CBearRun
Thanks for all the advice folks!
At least with this knowledge I can go in looking for what you have said and perhaps find the issue rather that thinking its one thing, getting there and its not. I would have been lost then.
I think the new relay sounds like a great upgrade and will be doing that anyway!
Oh dont worry Badger110, had this for a few years now but only just starting to attempt the work myself rather than pay a garage. More welcome to parenthood of trying to find cheap alternatives Big Cry
Post #739963 11th Nov 2018 10:50pm
