Home > V8 > oil pump housing plug size to remove aftermarket oil cooler |
muntz73 Member Since: 22 Jul 2018 Location: Atlanta Posts: 4 |
here is a photo of the oil cooler I wish to remove - or replace if I can't find the plugs to remove.
Click image to enlarge |
19th Oct 2018 2:00pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1749 |
Remove cooler and join pipes as a quick fix.
Engine cooling is done in the radiator on later vehicles. Your cooler would be for the transmission - auto or manual. Speak to Rovers North parts. Think this is what you have Part no. NRC8618 is your current fitting http://new.lrcat.com/#!/1228/12822/13646/1060/13685 This gives specs of the coupling so should help you. https://www.thexmod.com/item_detail.asp?id=1204 |
19th Oct 2018 4:04pm |
