Home > Puma (Tdci) > Injector cleaner - how often? |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2432 |
I would be careful. Drain any water collected in the fuel filter and then add the cleaner. Then I would change the fuel filter and engine oil. I`ve just used Liqui Moly diesel acconditioner/cleaner. Puma 110" SW
22nd Apr 2011 7:35am |
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 |
I heard that the Puma engine with its micro fine injectors may not appreciate any type of cleaner!!
Thoughts anyone? |
24th Apr 2011 6:32am |
I use Forte diesel treatment every 6 months. I just pour the litre bottle into a full fuel tank, and don't add 2stroke oil. The landy runs well on forte treatment.
24th Apr 2011 12:36pm |
CRJ Member Since: 12 Mar 2011 Location: Sealand - Denmark Posts: 253 |
Today I went to a nearby Ford dealer to get a oilfilter for my Defender. They told me that they used Bell Add 1D+ on puma 2,4 engines each time they was serviced - that was an authorized Ford dealer!!
CRJ 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
6th May 2011 2:59pm |
Ohh - and by the way I was also told that they have changed a lot of clutches and flywheels on Ford Transit...... 88 Ser. 3 1980 -sold
6th May 2011 3:00pm |
As told by the Ford mechanic I added 2 Bell add 1D+, because the car had been driven so little the past two years. It has all run through the engine now, and I belive ( I really believe) that the engine runs much smoother than before, especially under acceleration, I would give Bell Add my best recommondations. I had the car inspected monday, in order to get my licenseplates, and the guy doing the inspection was impressed about the pollution level - it was next to nothing
Regards CRJ 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
11th May 2011 2:35pm |
As written in another post, I have some serious issues with my engine knocking - happened 3 days after Bell Add treatment - I will not recommend it before I know what causes the knocking. 88 Ser. 3 1980 -sold
25th May 2011 10:10pm |
flying_low Member Since: 08 Apr 2011 Location: Masai Mara Posts: 19 |
Hi J, sorry to hear about the delayed knocking from the engine.. any idea what is causing the sound? sorry if i am asking too soon in case you are still in the process of looking into it.. Thanks .. and hope its not too serious. 2011 110 Tdci 1982 Range Rover V8 Classic (Gone) |
27th May 2011 6:04pm |
Hi. It was caused by one faulty injector - full description in http://www.defender2.net/forum/post73110.html#73110
27th May 2011 6:44pm |
Thank you.. very interesting .. oh, and apologies, i meant 'Hi CRJ' before .. 2011 110 Tdci 1982 Range Rover V8 Classic (Gone) |
27th May 2011 7:28pm |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 |
Don't add 2-stroke oil when using the Forte, or don't add 2-stroke ever? Cheers www.ralton.co.za |
29th May 2011 4:37pm |
I didn't add 2 stroke to the tank with the Forte treatment. Every other tank does get 2 stroke though |
29th May 2011 4:52pm |
IIRC my dealer adds Forte at every service. Steve.
29th May 2011 5:05pm |
