![]() | Home > Off Topic > New Suzuki Jimny |
edo Member Since: 20 Aug 2018 Location: Devon Posts: 379 ![]() ![]() |
worst performing car for some time on ncap. 3 stars.
More in common with the Defender than we thought!! ![]() |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1339 ![]() ![]() ![]() |
I'm actually surprised at how well it stood up to the tests, given the small size.
The passenger cell integrity looked pretty good on the front end collisions, although no images of the pedal box/bulkhead area after the impact, so not sure how knees/lower legs would have coped. |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 937 ![]() ![]() ![]() |
By its design/ladder chassis/size I think it will be a compromise in a crash.
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1121 ![]() ![]() ![]() |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 ![]() ![]() |
I saw one at the Nurburgring last week, looks really cool.
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 798 ![]() ![]() ![]() |
The L200 comes with a system called 'Super Select' which works quite well- It does allow you to use 4wd on the road as it employs a Torsen centre diff. The limitation of the system is similar to most part time 4wds as you cannot select low without the centre diff being locked. I use low with no CDL quite a lot off road (as well as moving trailers about). Best regards Chris |
SimonDavies Member Since: 15 Mar 2012 Location: Swansea Posts: 244 ![]() ![]() ![]() |
It looks fantastic. Still a small engine though, albeit slighty more cc than the original.
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6168 ![]() ![]() ![]() |
My 2007 shogun was similar ^^^
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2539 ![]() ![]() ![]() |
What's not to like?
![]() Mini Countryman Cooper S Morgan Plus 8 |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3820 ![]() ![]() |
From what I have seen so Far that's a better Defender replacement than the actual one.
It will also be affordable to most, the new Defender will not be. I need a bigger version though so a Jimny Max maybe in the future. It looks great ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17728 ![]() ![]() ![]() |
Sadly I doubt it can tow 3.5 tonnes, nor will it have the 1 tonne payload of a Defender.
Mind you I don't suppose the "new Defender" will either. ![]() |
a few look just like the landrover range . |
^^^^ Looks good
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10973 ![]() ![]() |
Looks ok, All those different configurations, reminds me of another 4x4
![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
