Home > V8 > HELP! ZF4hp22 noises!
atakanmerdin
Kenya
Hi Gents!
Someone help me identify this problem Sad
Whilst runnng in freshly rebuilt 4.2 in my 90. At highish rpm auto box suddenly let out screeching sound. Was near home so limped home. Screeches now permanently in hi Lo and neutral too. Some mechanical knocking sound too! What does this mean?
Sound is centrifugal! Increases with engine RPM. That’s to say higher frequency in N and in P.
Help this is the 3rd box she’s had Sad
Post #728664 12th Sep 2018 6:51pm
Alex1976
I don’t know a lot about auto boxes (although I have one in my Defender) but I would think this would be a torque converter issue possibly.
The guru of all things ZF is Dave Ashcroft - drop him an email or give him a bell and he will probably know exactly what the issue is and more importantly how to fix it.
Post #728665 12th Sep 2018 7:11pm
v8bob
United Kingdom 1998 Defender 90 300 Tdi HT Nato Green
I have looked at a few autos in my past. My first question would be why did you replace the previous box and how long ago?
Might be worth telling me the same on the previous boxes?
Post #728667 12th Sep 2018 7:19pm
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
Freshly rebuilt so you recently had the engine out? just wondering if a converter bolt has come loose or it hasn't be correctly engaged into the oil pump. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #728673 12th Sep 2018 7:35pm
atakanmerdin
Kenya
Was manual. Change to auto was due to fiancé as an engagement gift. Car was the gift had to be auto...
First box was duff wouldnt shift and it came with the engine. Second one too had only reverse gear (believe blown A clutch pack).
Was careful with the torque converter spacing and installation with this box and it drove well for a week shifting all through and locking up.
On high RPMs today the screeching scratching hippies started definitely a spinning sound as increases with engine speed i.e higher frequency in P and N.
Someone suggested checking “Maybe one of the torque converter bolts backed out? Check under the cover”
Post #728674 12th Sep 2018 7:35pm
v8bob
As you say torque converter installation was done carefully then I would assume all the bolts were fitted correctly and torqued to spec.
Screaching would suggest a bearing problem. See if you can borrow a stethoscope and find out where the noise is loudest.
If it is from the box... It is worth looking at the trans oil cooler circuit. Kinked pipes, blocked cooler, blocked pipes, plastic plug not removed. The lube circuit is generally first thing to suffer if you have a problem with the cooler circuit.
Post #728680 12th Sep 2018 8:07pm
atakanmerdin
Kenya
Thanks will have a look. I’m almost convinced it sounds like a loose bolt and rotational scratching against metal. Maybe I just want it to sound like that...
A loose torque converter should knock? The mechanical sounds did sound like knocking around. Possible to damage flex plate on high load?
Post #728681 12th Sep 2018 8:10pm
atakanmerdin
Kenya
What it sounds like, a lot screechier in person
Post #728684 12th Sep 2018 8:29pm
atakanmerdin
Kenya
Bump!
Post #728687 12th Sep 2018 9:03pm
jst
Does it still have drive? If so oil pump is working and engagement is correct
Tc bolt come out? Check through s/m hole, remove bottom inspection plate? What in there any thing unexpected?
Not something stupid like handbrake shoes? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #728692 12th Sep 2018 9:24pm
atakanmerdin
Kenya
She still has drive, forward and reverse. Gearing to check inspection hole.
Post #728693 12th Sep 2018 9:26pm
atakanmerdin
Kenya
Who wants to have a laugh!
Radiator and bonnet stay rod came off mounting contacting engine front end...
Noise transmitted through whole in floor...
test driving now to fully eliminate transmission
Damage to viscous fan blades and coolant pipes.
Rover life
Post #728712 13th Sep 2018 5:35am
v8bob
At least it is good that you don't have to take the gearbox out Smile
Post #728715 13th Sep 2018 6:50am
Mo Murphy
Laughing I'd rather change the viscous fan and some hoses than change the gearbox !
50 Shades of Pennine Grey
Post #728729 13th Sep 2018 8:19am
atakanmerdin
Kenya
Yes! Thank the rover gods!
And thanks to all for the invaluable and quick advise and responses!
Post #728796 13th Sep 2018 4:55pm
