![]() | Home > V8 > HELP! ZF4hp22 noises! |
Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596 ![]() ![]() |
I don’t know a lot about auto boxes (although I have one in my Defender) but I would think this would be a torque converter issue possibly.
The guru of all things ZF is Dave Ashcroft - drop him an email or give him a bell and he will probably know exactly what the issue is and more importantly how to fix it. |
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 324 ![]() ![]() ![]() |
I have looked at a few autos in my past. My first question would be why did you replace the previous box and how long ago?
Might be worth telling me the same on the previous boxes? |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 923 ![]() ![]() ![]() |
Freshly rebuilt so you recently had the engine out? just wondering if a converter bolt has come loose or it hasn't be correctly engaged into the oil pump. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
atakanmerdin Member Since: 15 Dec 2017 Location: Nairobi Posts: 26 ![]() ![]() |
Was manual. Change to auto was due to fiancé as an engagement gift. Car was the gift had to be auto...
First box was duff wouldnt shift and it came with the engine. Second one too had only reverse gear (believe blown A clutch pack). Was careful with the torque converter spacing and installation with this box and it drove well for a week shifting all through and locking up. On high RPMs today the screeching scratching hippies started definitely a spinning sound as increases with engine speed i.e higher frequency in P and N. Someone suggested checking “Maybe one of the torque converter bolts backed out? Check under the cover” |
As you say torque converter installation was done carefully then I would assume all the bolts were fitted correctly and torqued to spec.
Screaching would suggest a bearing problem. See if you can borrow a stethoscope and find out where the noise is loudest. If it is from the box... It is worth looking at the trans oil cooler circuit. Kinked pipes, blocked cooler, blocked pipes, plastic plug not removed. The lube circuit is generally first thing to suffer if you have a problem with the cooler circuit. |
Thanks will have a look. I’m almost convinced it sounds like a loose bolt and rotational scratching against metal. Maybe I just want it to sound like that...
A loose torque converter should knock? The mechanical sounds did sound like knocking around. Possible to damage flex plate on high load? |
What it sounds like, a lot screechier in person |
Bump!
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8166 ![]() ![]() ![]() |
Does it still have drive? If so oil pump is working and engagement is correct
Tc bolt come out? Check through s/m hole, remove bottom inspection plate? What in there any thing unexpected? Not something stupid like handbrake shoes? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
She still has drive, forward and reverse. Gearing to check inspection hole.
Who wants to have a laugh!
Radiator and bonnet stay rod came off mounting contacting engine front end... Noise transmitted through whole in floor... test driving now to fully eliminate transmission Damage to viscous fan blades and coolant pipes. Rover life |
At least it is good that you don't have to take the gearbox out
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2279 ![]() ![]() ![]() |
![]() Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
Yes! Thank the rover gods!
And thanks to all for the invaluable and quick advise and responses! |
