![]() | Home > Maintenance & Modifications > Heater switch light flickers on / off easy fix. Puma? |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 ![]() ![]() ![]() |
"custom90steve" docet !
![]() ![]() Click image to enlarge
http://www.defender2.net/forum/topic16996.html Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20718 ![]() ![]() |
![]() A drinking straw may do the job too if you can find the right size. ![]() ⛽️🛢️⚙️🧰💪 |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3818 ![]() ![]() |
^ Great
Will have a look and print this out, |
a couple of bits of rubber hose pushed over some circlip pliers works well. But so long as they're not hot you can normally pull them out with your fingers.
![]() Sorted, long nose pliers and masking tape on the end... 5 min job it works. Its been iffy for ages !!! ![]() Click image to enlarge thanks |
Mwd Member Since: 12 Jan 2016 Location: Scottish Highlands Posts: 45 ![]() ![]() |
How do you get the front of the instrument panel off? I've removed the two torx screws but it still seems firmly attached and I'm reluctant to try prising it off in case I break something expensive!
take the radio out, remove the two torx screws then give it a good pull. (it's retained by some spring clips.)
Just sorted mine - thank you for the helpful advice. Three out of four bulbs had blown (after £70k miles / 6 years) and we’re replaced so the controls should be easier to find at night now!
