Home > Maintenance & Modifications > Heater switch light flickers on / off easy fix. Puma?
Stacey007
Hello
The heater knob on the left back illumination works sometimes but mainly not.
Is this just a bulb I need and undo the dash. Or is it the holder of the bulb I may need?
Post #723745 16th Aug 2018 9:18am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
"custom90steve" docet !
Wink
custom90steve wrote:
1
4 As previously suggested on here by Mal (K9F) a kids drinking straw may well work well too. I however didn't have one to hand so used my method pictured.
http://www.defender2.net/forum/topic16996.html Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #723755 16th Aug 2018 9:40am
Thumbs Up Justgo very easy with the bulbs and don't put too much pressure on them.
A drinking straw may do the job too if you can find the right size.
Thumbs Up TheThunder Rolls🇬🇧🇺🇸
Post #723767 16th Aug 2018 10:20am
Stacey007
^ Great
Will have a look and print this out,
Post #723774 16th Aug 2018 10:47am
zsd-puma
a couple of bits of rubber hose pushed over some circlip pliers works well. But so long as they're not hot you can normally pull them out with your fingers.
Post #723813 16th Aug 2018 2:03pm
Stacey007
Thumbs Up
Sorted, long nose pliers and masking tape on the end... 5 min job it works. Its been iffy for ages !!!
thanks
Post #723963 17th Aug 2018 10:39am
Post #723964 17th Aug 2018 10:42am
Mwd
How do you get the front of the instrument panel off? I've removed the two torx screws but it still seems firmly attached and I'm reluctant to try prising it off in case I break something expensive!
Post #730938 24th Sep 2018 7:12pm
zsd-puma
take the radio out, remove the two torx screws then give it a good pull. (it's retained by some spring clips.)
Post #730987 24th Sep 2018 8:49pm
Mwd
Just sorted mine - thank you for the helpful advice. Three out of four bulbs had blown (after £70k miles / 6 years) and we’re replaced so the controls should be easier to find at night now!
Post #731129 25th Sep 2018 3:50pm
