Home > Td5 > Weird knocking noise. |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 |
Does it happen parked up?
2nd Aug 2018 5:23am |
Chamois Member Since: 24 Dec 2015 Location: Wanaka/Chamonix Posts: 114 |
Hi
yeah does it parked. Winter's here, thanks goodness! |
2nd Aug 2018 5:54am |
does it make a difference whether the aircon is on or off ? aircon clutch ?
2nd Aug 2018 9:13am |
remove drive belt check all pultey baring
2nd Aug 2018 10:18am |
No air con on this one.
Will have a look at all the Pully bearings tomorrow. Thanks Winter's here, thanks goodness! |
2nd Aug 2018 10:56am |
Checked pully's and all seem fine apart from the water pump which seems to have a bit of play when you rotate it? Is that normal? Winter's here, thanks goodness!
3rd Aug 2018 5:32am |
Check the power steering pipe is tight into the pump. Ray
4th Aug 2018 11:38pm |
Hi, will have a look tomorrow. Thanks! Winter's here, thanks goodness!
7th Aug 2018 6:40am |
