![]() | Home > Td5 > Weird knocking noise. |
Does it happen parked up?
Chamois Member Since: 24 Dec 2015 Location: Wanaka/Chamonix Posts: 114 ![]() ![]() |
Hi
yeah does it parked. Winter's here, thanks goodness! |
does it make a difference whether the aircon is on or off ? aircon clutch ?
remove drive belt check all pultey baring
No air con on this one.
Will have a look at all the Pully bearings tomorrow. Thanks Winter's here, thanks goodness! |
Checked pully's and all seem fine apart from the water pump which seems to have a bit of play when you rotate it? Is that normal? Winter's here, thanks goodness!
Check the power steering pipe is tight into the pump. Ray
Hi, will have a look tomorrow. Thanks! Winter's here, thanks goodness!
