Home > Td5 > td5 cut out
buds
td5 cut out
hi
dont know if anyoe can help but today the wife was driving my defender and it just cut out she pulled over switched the key off and on again and it started and has run ok for 40miles has anyone got any ideas on this
Question
Post #67186 13th Apr 2011 4:41pm
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
i think there is a safety cut out button on the front of the bulk head near the middle, you may need to reset this perhaps Confused 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #67205 13th Apr 2011 7:12pm
buds
thanks will have a look
Post #67215 13th Apr 2011 8:10pm
RobKeay
Make sure there's no oil getting to the ecu!
Post #67218 13th Apr 2011 8:59pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Unlikely, if that trips it needs resetting before you can go again and you said it restarted.
Have a look at the fuel pump relay connections, maybe give them a little tweak to get a better connection?
Steve
Post #67219 13th Apr 2011 9:00pm
buds
hi
all was ok there was there any other ideas anyone might have
Post #67350 14th Apr 2011 6:58pm
Might pay to plug in a nanocom or similar and check for any engine faults.
Mine (which is tweeked a bit) sometimes does that, especially if i boot it under certain conditions, it freaks the ECU out and it just stops dead. only done it twice though, thankfully.
maybe your turbo actuator is stuck and it's overboosting?
Post #67399 15th Apr 2011 6:40am
buds
ok jim will give it a try thanks
Post #67459 15th Apr 2011 5:13pm
shachar
Israel
look at the CKP - crank position sensor.
sometime it gets oil into the connector.
its on the rear side of engine under the fuel regulator
Post #72923 26th May 2011 4:19pm
