![]() | Home > Td5 > td5 cut out |
chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 897 ![]() ![]() ![]() |
i think there is a safety cut out button on the front of the bulk head near the middle, you may need to reset this perhaps
![]() Beer 'n Sex 'n Chips 'n Gravy ![]() |
buds Member Since: 30 Aug 2010 Location: isle of wight Posts: 15 ![]() |
thanks will have a look
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1590 ![]() ![]() ![]() |
Make sure there's no oil getting to the ecu!
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 587 ![]() ![]() ![]() |
Unlikely, if that trips it needs resetting before you can go again and you said it restarted.
Have a look at the fuel pump relay connections, maybe give them a little tweak to get a better connection? Steve |
hi
all was ok there was there any other ideas anyone might have |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6124 ![]() ![]() ![]() |
Might pay to plug in a nanocom or similar and check for any engine faults.
Mine (which is tweeked a bit) sometimes does that, especially if i boot it under certain conditions, it freaks the ECU out and it just stops dead. only done it twice though, thankfully. maybe your turbo actuator is stuck and it's overboosting? |
ok jim will give it a try thanks
shachar Member Since: 26 May 2011 Location: Israel Posts: 1 ![]() ![]() |
look at the CKP - crank position sensor.
sometime it gets oil into the connector. its on the rear side of engine under the fuel regulator |
