Home > Puma (Tdci) > Output shaft failure, Forum Survey
Page 24 of 33 <123 ... 232425 ... 313233>
Caterham
is that a little like building a crane using hessian rope rather than steel but supplying it with a trampoline just in case the hessian gives way?
Post #936482 5th Jan 2022 6:55pm
You have finally lost me or the plot, or both! Rolling with laughter Thumbs Up
Post #936503 5th Jan 2022 8:56pm
LR90XS2011
think we forgot the crappy front diff fitted to some models
the Seat Belt bracket bolts on some 2010/11 models
oil pump issues on 2.2s
but we all still love them and they are currently still strangely going up in value DEFENDER 90 TDCI XS,
Post #936524 5th Jan 2022 10:04pm
Jonothethird
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Tonga Green
Thanks for all the helpful replies. I am now not only concerned about grinding to a halt with output shaft failure, but also about terminal engine failure, clutch failure and my axle ends falling off Laughing Shocked How is it actually possible to engineer a car with all these problems!!
I haven’t had my Defender for long so hopefully it was either a ‘goodun’ or someone else sorted these things out before me - it’s got a good (mainly LR) service history… The clutch seems strong (bit of a rattle when cold sometimes when the pedal is released but I’m told that’s ‘normal’ Neutral ) so I guess someone has probably replaced it previously from what you say. I didn’t realise Puma clutches were so bad. What are the signs that the clutch is going?
I’ll have to check the sump issue as I do go off-road - hopefully it has also been sorted! Is it easy to tell by looking at it?
I think I’ll just have to hope for the best with the output shaft as it seems a big expense to change something that might be absolutely fine and I’m not planning any long distance expeditions (sadly!). I might just upgrade the breakdown cover though Laughing
Post #936536 5th Jan 2022 11:03pm
Don't be put off, they're great vehicles and we love them (it's just a pity there were so many unnecessary mistakes). Every journey is an adventure in a Defender.
Breakdown and recovery insurance is great for peace of mind, it must be said.
There is also a lot of great people on this forum who are happy to help (and to scare the bejasus out of you, of course)! Laughing
Post #936540 5th Jan 2022 11:53pm
Jonothethird
Thanks Blackwolf. I have always wanted one and definitely plan to keep it forever…just wasn’t aware there were so many issues!! So far so good - had it nearly a year and nothing has broken yet! Drives pretty well actually. I’ll post some pics in due course. Thumbs Up
Post #936541 6th Jan 2022 12:54am
Caterham
probably/hopefully both Laughing
brackets to catch wheels as they fall off. trampolene for catching the crane's load as the rope breaks Mr. Green
did I mention I bought a transit van?
while cleaning it the other day it occurred to me how practical it is in almost every way and it got me thinking about the defender. yes the defender is far more capable in the snow / mud BUT I had to ask myself - what would I prefer - to get stuck or to breakdown? Very Happy
I'm luck to have the choice I guess - although things as they are I don't believe I've gotten close to 500 miles in the defender over the last 12 months
Post #936554 6th Jan 2022 9:25am
500 miles .... so you've only used about four gallons of fuel in your Defender then! Rolling with laughter Thumbs Up
Post #936565 6th Jan 2022 11:25am
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
What a positive thread Laughing
There are two factors that the survey does not take into account. Driving conditions and style.
Off-road vs on-road will have a massive impact. The additional torque off-road driving places on the shaft. One mile off-road equals many many more in the smooth black stuff.
Also driving styles. Not just when changing gears but are individuals pre-torquing the drivetrain when off-roading for example?
I believe these two factors are more of a contributor than alignment issues.
Post #936583 6th Jan 2022 2:15pm
Caterham
Laughing come to think of it I might not have put any fuel in during the year on the basis that I typically get 500 miles from a tank Mr. Green
Post #936622 6th Jan 2022 7:45pm
Caterham
I'd love to agree with you. While you're not wrong I've had two failures plus if my memory serves me right a 3rd replaced at the time of a clutch replacement (or gearbox or transferbox - can't quite remember) - but anyway although I've now done in excess of 100k miles I'd suggest there's unlikely to be another defender out there thats been treated more gently ie very little towing and largely slow motorway cruising (hence managing 40mpg average on a tank). So while your theory is correct I'm inclined to suggest there is a fundamental issue other than driving style.
Post #936624 6th Jan 2022 7:50pm
LR90XS2011
What Caterham said
mine had a very easy first 20k miles and 2 shafts, neither failed but both on the way, now on my 3rd this one is Ashcroft so time will tell.
Coincidently both Caterham and mine are 2011 DEFENDER 90 TDCI XS,
Post #936628 6th Jan 2022 8:06pm
doublea
Scotland 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
doublea wrote:
My sister's 90sw
1, vehicle year of manufacture :2013
2, engine type 2.4 or 2.2 :2.2
3, is the Defender still running with the original output shaft? (Y/N) :N
4, vehicle milage at first shaft failure, or current milage on the original shaft if still running. :22,000
If the shaft has previously failed, please answer 5 & 6.
5, Has an Ashcroft modified part has been fitted? (Y/N) N - standard parts fitted under warranty
6, vehicle milage at the second failure, or milage if still running. No second failure yet, 48,000.
No off roading, not much mechanical sympathy either!
Updated...
6, vehicle mileage at the second failure, or mileage if still running. Second failure (standard JLR parts) 71,000 Current Steeds:
2015 110 UW in Grasmere Green
2003 BMW F650 the Hack
2000 Elise
1992 Ducati 888 (no longer in bits, yahoo)
1990 TDR 250 (in bits again)
1988 TDR 250 (no longer in bits) and for sale
Post #937277 11th Jan 2022 11:01pm
MK
I am wondering what happened with Keith´s case Puma 110" SW
Post #937280 11th Jan 2022 11:14pm
SJM2018
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Aintree Green
1, vehicle year - 2011
2, engine type 2.4
3, is the Defender still running with the original output shaft? No
4, vehicle milage at first shaft failure, or current milage on the original shaft if still running - 52,000
Was having a LOF clutch kit fitted, so opted to get the Ashcroft Output shaft at the same time.
Here are some pics (note I’ve done 34k of the 52k miles and while it’s extremely well looked after, it has a BAS tune and is driven hard).
 2011 CSW XS 90
Post #937402 12th Jan 2022 7:58pm
