![]() | Home > Maintenance & Modifications > Shielder bulkhead |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 798 ![]() ![]() ![]() |
I have known 2 Genuine LR bulkheads stripped and galvanised with no ill effects. Chunky bit of box bolted across the mounts and the mesh cut out of the vents- all good. Chris |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
I agree that it would be disappointing to find Shielder's bulkhead is all out of spec, but searching about the web that doesn't seem to be the case, I've located some more positive reviews on other forums.
I also see that LRPARTS are also reselling them: https://www.lrparts.net/lrc3023-shielder-g...oated.html which gives me a little more confidence in the quality, and including delivery and VAT that is coming in at £1662. Does anyone have any idea if the +£200 option for powder coating over the galvanized metal makes painting it easier or harder? I am not planning to paint it myself, instead finding a paintshop somewhere local to do it. 2005 Td5 90 XS 1989 V8 110 CSW |
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 290 ![]() ![]() ![]() |
Having worked in the R&D Dept. for a powercoat manufacture in southern England. The quality of powdercoat varies from excellent to
![]() My thought would be stick with the galvanised, get a body shop to prime, paint and clear coat to a high specification, ideally if you know somebody in a body shop all the better, don't get them to skimp or do it on the cheap, pay more for extra layers of all 3. Than after/during install waxoyl/dintrol/dynax (choice of sealant) liberally to protect. Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1646 ![]() ![]() |
If you have a look bearmach do bulkheads as well.cheaper for sure. not perfect but 3yr warranty and they are getting better with every batch.
arrive well packed next day if in stock. fit it then remove it then brace it get it dipped clean and rethread all the holes and refit. Cambrian 4x4 did a very honest and fair report on fitting one supplied by a customer. pictures and explanation of what was wrong was factual. lots of other garages report the same issues nobody near me will fit them......and a few have tried |
Which ones won't the local garages fit Mdm, the Bearmach ones, or the Shielder ones? 2005 Td5 90 XS
1989 V8 110 CSW |
shielder
the bearmach ones are not perfect but better the paint is poor at best they dont have every bracket for every year but the ones weve fitted have been ok |
Bother, OK thanks for the information Mdm. I shall ponder the decision a bit longer
![]() 1989 V8 110 CSW |
sorry i dont often knock businesses but i dont like folk spending their hard earned cash to get the sort of issues that these bulkheads throw up.ill pm you some picture s of the one we fitted to my last rebuild
Inguz Member Since: 06 Sep 2020 Location: In the wild Posts: 101 ![]() |
Did you take the plunge on either? I'm in the same boat not knowing which route to go down. |
if you have a google Cambrian 4x4 in wales did a very fair and unbiased review of the one they fitted for a customer. it makes sober reading as the amount of hours to get it fitted was massive.
no i wouldn't powder coat anything on a landy bar wheels. find a decent paint shop. we would fit everything to the new one and then fit it to the chassis, then remove it and strip then paint and rebuild for the final time. then add wax/ rust proofing to any cavities and the usual rust traps. ![]() Click image to enlarge ![]() Click image to enlarge bearmach one test fit on a richards chassis |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1885 ![]() ![]() |
I’m currently trying to help a friend fit a Sheilder bulkhead to his 1997 300Tdi.
We only got it onto the car today, and the list of glitches is pretty long already;
No holes in the footwells for the chassis to bulkhead brackets; No holes for the ‘fusebox’ retaining bolts - and the pressing for the wiring and relay bases is the wrong shape and place; No holes for the Alarm ecu; No holes on the top of the footwell for the door check bracket, and the ones on the inner face of the bulkhead are too high, and won’t allow the bracket to fit; The “step” from the top half of the inner bulkhead face down to the fusebox face barely exists; Looks like the n/s bulkhead pillar is about 10mm out (expecting issues fitting the door); The lip on the n/s footwell to hold the floor panel looks to be too low (causing the floor panel to sit way off level). That’s all the stuff I remember so far. I’ll maybe take and post pics with my friend’s permission. I have looked at the Cambrian 4x4 posts on Fbook - but hadn’t seen that when my mate was research8ng his purchase - how many DIY folk will have a handy bulkhead jig!! This is the third bulkhead swap I’ve done now, so not my first rodeo, but the first two were genuine bulkheads which had been galved. Nothing like the issues we’re having now. It looks like we might need to do a ‘quick and dirty’ fit up now, to check the alignment of other things like windscreen / doors / wings / roof before taking it all off again to ‘do it properly’ - assuming it’s going to be possible to make it fit. If it were me, I think I’d be getting in touch with them, and researching the small claims court. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
billy56 Member Since: 05 Oct 2013 Location: Co Antrim Posts: 20 ![]() ![]() ![]() |
I have got one fitted in the last month and it was the second in a row for the guy who did it and he was pleasantly surprised at how well they fitted, but he will not fit their chassis for any money🤣
