Home > Maintenance & Modifications > Shielder bulkhead
Page 3 of 5 <12345>
Hufflepuff
trickster5000 wrote:
Hufflepuff - yes totally brand new Thumbs Up
Thanks Matt. I'll ponder it over the weekend and give them a call next week. 2005 Td5 90 XS
1989 V8 110 CSW
Post #727854 7th Sep 2018 11:11pm
Procta
L110CDL wrote:
Hi Matt, good positive feed back Thumbs Up
I know this maybe a silly Q or i have missed something somewhere, but why 2 chassis Whistle
I had to read twice there, when he said bulkheads and chassis, then look twice at the photos of the chassis!
Let us know how things turn out trickster, Are you going to be revamping other parts or is just a case of swopping what you have over? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #727859 8th Sep 2018 12:10am
trickster5000
United Kingdom 1989 Defender 90 300 Tdi CSW Arles Blue
Hi Procta, looking to re-use as much as possible but some things just aren't worth trying to recover especially things like the fuel tank which are a bit of a pain to replace when it's all back together so best just do it properly now while it's all in bits Thumbs Up Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html
Post #728076 9th Sep 2018 1:50pm
billy56
United Kingdom 1991 Defender 90 200 Tdi HT Arles Blue
I've just had a good look at a load of chassis and two bulkheads that must be waiting for the boat to the mainland
they seem well made and the welding and galvanising look good, bulkheads look well made holes seems to be in the right place
only thing I noticed were the brackets for the bonnet hinge inserts were knocked back closed but would straighten All right
I took a few photos but not sure how to load on the post Very Happy
Post #728507 11th Sep 2018 5:31pm
Ghound
United Kingdom 1999 Defender 110 Td5 SW Alaska White
I can see where they have notched out the metal around the inner corners of the 2 air vents, originally these have a return lip, and you either have a glued in rubber seal, or the foam seal on the vent flap.
There doesn't seem to be a return lip or enough metal left in the corners to make a water tight seal, 50mph in driving rain could see flooded footwells, even original Land Rover bulkheads leak there.
Best bet is to wait until the first lot have been fitted and used for a period of time, and any problems have been ironed out.
Post #728576 12th Sep 2018 8:03am
VVS210
Very interested to see how you get on with these, especially whether holes line up for fitting the various bits. If all good then certainly better than a refurbed bulkhead in my opinion & will be on the list for when I need to rebuild mine Thumbs Up
Post #728580 12th Sep 2018 8:33am
Roscobus1
United Kingdom 2001 Defender 110 Td5 CSW Alaska White
My advise to everyone is stay clear!! I've just had my second TD5 bulkhead delivered as first one was miles off! ( 7 weeks to deliver instead of 3 promised ). 2nd one delivered less than an hour ago and it's even worse!!! Waiting on Paul ( owner ) calling me bk as I want a full refund plus the Labour costs to find out the 1st one was duff!!! I'm now 2 and a half months behind on build and £1800 down. Stay away from them is my 1st hand advice. Will post Paul's response.
Ross
Post #731335 26th Sep 2018 2:12pm
rallysteve
Which aspect is miles off?
Post #731340 26th Sep 2018 2:23pm
Roscobus1
Hi Steve,
Have a look at the gallery. Everything about sums it up. Width is out, size of vent areas are all different on each side, height is forcing my roof up nearly 20mm. It's a joke!
Post #731341 26th Sep 2018 2:28pm
rallysteve
That does look pretty shocking! I had a similar issue with my own bulkhead pushing the roof up a bit at the front (i refurbed it myself) but as we had changed the bulkhead outriggers, bulkhead feet and vent flap section any one or all of those could have contributed. Mine was only out 5mm at the back of the roof though (truckcab)
Post #731344 26th Sep 2018 2:51pm
Bows
Wales 2006 Defender 110 Td5 SW Alpine White
Oh. O, I have one on order!!! 2006 TD5110 station wagon
1995 300Tdi 90 truck cab
1989 90 hard top with 200 tdi
1983 110 hard top
1983 110 Hi cap
1954 107 pick up
Post #731346 26th Sep 2018 2:55pm
Roscobus1
Sorry Bows but I'd prepair to be disappointed. If not to late I'd cancel and try get ur money back.
Post #731348 26th Sep 2018 3:55pm
VVS210
Shocked
Post #731366 26th Sep 2018 6:40pm
Ghound
It's miles out, very poor job.
Ross
Post #731801 28th Sep 2018 11:51pm
Hufflepuff
I am confused. The following website "TerrainTechParts" for a company based in Axminster states that they have been fabricating parts for 28 years, yet the pictures are the same as on Shielder's website?
https://www.terraintechparts.com/products/...d-assembly
Do we assume that TerrainTechParts is just a reseller for Shielder? If so that's pretty misleading on their website. Or did Shielder 'borrow' the pictures from TerrainTechParts? Hmm... They claim they are in stock too.
Has anyone had any dealings with these guys? 2005 Td5 90 XS
1989 V8 110 CSW
Post #732321 1st Oct 2018 10:02pm
Page 3 of 5 <12345>
