Home > Puma (Tdci) > Oil change with extractor |
Yes I have it and it's a "must have"!!!!! easy job!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
10th Aug 2020 8:02am |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1081 |
I tried to suck out some oil using a pump such as the Pela.
I fitted a thinner hose to fit in the 2.2's tube. But it only sucked a little oil and mostly air. I realised the hose wasn't in deep enough. There is a resistance (which you can also feel with the dipstick) and I didn't dare to force it down the last 10cm, fearing it may tear apart Did you just push it in with force? |
26th Aug 2021 11:19am |
carpetsauce Member Since: 19 Mar 2021 Location: Essex Posts: 58 |
Sorry if this point has been made before but the Pela draws the oil up much better if the engine oil is hot. Not quite such an issue in the summer but certainly for the other 11 months of the year.
26th Aug 2021 1:35pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8088 |
Ref filter making a mess, try using hand around a plastic bag that's up around the filter. Catch oil and filter in the bag. Mind oil temp! Cheers
26th Aug 2021 8:25pm |
fidocrew Member Since: 01 Sep 2012 Location: Who knows Posts: 29 |
top tip
26th Aug 2021 9:46pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3685 |
Genius!! |
27th Aug 2021 5:05am |
