Home > Puma (Tdci) > Oil change with extractor
Page 3 of 3 <123
dgardel
Italy
blackwolf wrote:
Why not fit a Difflock drain plug and solve all your problems? See http://www.defender2.net/forum/topic29173.html for more info and links.
I use one since it avoids the need to remove my underbody protection to drain the oil.
Yes I have it and it's a "must have"!!!!! easy job!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #848966 10th Aug 2020 8:02am
ngins
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Corris Grey
Thanks. Another vote for the difflock femco plug then Smile.
How about oil extractor? - I am only still thinking about it as I could use it for other things too so I might get more bang for buck!
Anyone had any issues with garages and the difflock plugs if you don’t always do your own servicing. I guess they are reasonably common.
Post #848980 10th Aug 2020 8:49am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
I tried to suck out some oil using a pump such as the Pela.
I fitted a thinner hose to fit in the 2.2's tube. But it only sucked a little oil and mostly air.
I realised the hose wasn't in deep enough. There is a resistance (which you can also feel with the dipstick) and I didn't dare to force it down the last 10cm, fearing it may tear apart Embarassed
Did you just push it in with force?
Post #918772 26th Aug 2021 11:19am
carpetsauce
Sorry if this point has been made before but the Pela draws the oil up much better if the engine oil is hot. Not quite such an issue in the summer but certainly for the other 11 months of the year.
Post #918782 26th Aug 2021 1:35pm
jst
Ref filter making a mess, try using hand around a plastic bag that's up around the filter. Catch oil and filter in the bag. Mind oil temp! Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #918835 26th Aug 2021 8:25pm
fidocrew
United Kingdom 1998 Defender 90 300 Tdi CSW Epsom Green
Thumbs Up top tip
Post #918846 26th Aug 2021 9:46pm
Co1
Genius!!
Post #918851 27th Aug 2021 5:05am
Page 3 of 3 <123
