![]() | Home > Maintenance & Modifications > Black smoke at low RPM |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Has the car always been like this since the tuning ?
Who did the tuning ? Which filling station do you fill up at ? Have you had any diagnostics done ? Regards Pete |
Bish Member Since: 11 Nov 2008 Location: Hungerford Posts: 429 ![]() ![]() |
It has occasionally done since tuning......but not always. More so now.
TD5 Alive BP Nope not yet |
Hi
I think the first port of call is a diagnostic chq to make sure all seems in order with the electronics side of things. This may point you in the direction of a fault if there is one,i take it was doing this same thing before it was modifyed and tuned ? Regards Pete |
Nope, not even a puff of smoke beforebeing tuned.
I will go and slap her on the diagnostic and see what comes up. |
May be the tuning has done this !
Did you get the tuning done via mail or did you take the car and have the work done ?? Regards Pete |
Hi Pete
I took the car up there to have it done. Cheers Mike |
Then i would see what the diagnostic brings and hope it brings a ault to light.
Regards Pete I you fancy a trip to York ill sure take a look for you. |
