Home > Maintenance & Modifications > Black smoke at low RPM
Bish
2002 Defender 90 Td5 XS CSW Java Black
Hi Chaps,
I have a TD5 with re-map, boost box, intercooler, egr, exhaust and pipes. After about 3 or 4 miuntes of driving blake smoke comes out of the exhaust at low RPM and clears when the RPM builds. If I switch the engine off and then back on again it clears up for 5 or so minutes then the same thing happens.
Performance does not seem effected at all.
I would be interested to hear your thoughts.
Thanks Bish
Post #4610 11th Nov 2008 11:22am
bell-auto-services
Has the car always been like this since the tuning ?
Who did the tuning ?
Which filling station do you fill up at ?
Have you had any diagnostics done ?
Regards Pete
Post #4656 12th Nov 2008 7:37pm
Bish
It has occasionally done since tuning......but not always. More so now.
TD5 Alive
BP
Nope not yet
Post #4668 13th Nov 2008 4:19pm
bell-auto-services
Hi
I think the first port of call is a diagnostic chq to make sure all seems in order with the electronics side of things.
This may point you in the direction of a fault if there is one,i take it was doing this same thing before it was modifyed and tuned ?
Regards Pete
Post #4673 13th Nov 2008 5:50pm
Bish
Nope, not even a puff of smoke beforebeing tuned.
I will go and slap her on the diagnostic and see what comes up.
Post #4684 14th Nov 2008 11:36am
bell-auto-services
May be the tuning has done this !
Did you get the tuning done via mail or did you take the car and have the work done ??
Regards Pete
Post #4686 14th Nov 2008 11:44am
Bish
Hi Pete
I took the car up there to have it done.
Mike
Post #4696 14th Nov 2008 6:27pm
bell-auto-services
Then i would see what the diagnostic brings and hope it brings a ault to light.
Regards Pete
I you fancy a trip to York ill sure take a look for you.
Post #4698 14th Nov 2008 7:57pm
