![]() | Home > Maintenance & Modifications > Intermittent Front Wiper- variable delay |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7916 ![]() ![]() ![]() |
Seen these on ebay from Lithuania, but is that a reason to avoid??
http://www.ebay.co.uk/itm/AUDI-VW-SEAT-SKO...SwiLdWAIRQ |
Bought the real 99 VW relay at the time from my local VW dealer, works fine for 5 years now... You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
adamatdraycott Member Since: 11 Nov 2013 Location: Midlands Posts: 299 ![]() ![]() ![]() |
Update, just been out with a meter to check what is going on
Found that there now appears to be a delay on the wiper signal when washing the screen. So when britpart state that if you give the screen a quick wash it wipes only once... Isn't entirely true. You now have to wash the screen for a second or so before the wipers will wipe 3 times I'm not entirely happy with this, but will keep the relay in for now and see how I get on |
MC84 Member Since: 23 May 2016 Location: Near Bristol Posts: 360 ![]() ![]() ![]() |
I've just swapped in a relay 99 to my 2001 Defender 90 TD5 but found the relay in the fuse box by the gear levers and not behind the dash.
Before [/img][URL=] ![]() Click image to enlarge[/URL] After ![]() Click image to enlarge[/URL][/img] Wheres the relay for the rear door wiper? I can't find it!!! Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
In the door itself on a Puma. Take the door card off and look see! If you go through life with your head in the sand....all people will see is an ar5e!!
Unfortunately I only have an old 2001 TD5 although I guess it could be in the door. I'll have a listen!
WilkoW Member Since: 09 Jun 2013 Location: Northants Posts: 84 ![]() ![]() ![]() |
Thread revival: is it possible to fit a rear windscreen wiper with intermittent relay on a 2008 Puma 110 model? If so, any links please?
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4800 ![]() ![]() ![]() |
Have you tried using the search button Wilko? 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
Yes. I just get 404 errors. Thanks for your input - most useful.
Your sarcasm will get you far on here
![]() 2008 SVX 90 2000 XS TD5 90 |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2240 ![]() ![]() |
Looking for a new version of the variable “99” relay that did not cost the earth I found this https://www.carbuilder.com/uk/programmable...iper-relay
At £12 + £3.90 delivery it’s a good price but I’m unaware of the quality. Do the experts think this has the right physical and electrical connections ? |
