Home > Maintenance & Modifications > Intermittent Front Wiper- variable delay
Page 3 of 6 <123456>
Dave-H
Dave-H wrote:
Just done mine .. got lucky on E-bay [been looking for weeks] picked one up for £6 inc delivery Cool
What a brilliant mod! Why do LR not sell them like this??
And used it in anger today [been drizzly all bloody day] .... what a brilliant mod Cool Makes a world of difference Guns and Landrovers .... anything else is irrelevant.
Post #73520 30th May 2011 9:24pm
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I finally got around to fitting the proper spec "99" relay. I finally have programmable variable relay! Very Happy
One thing I did notice is that the wash function only wipes once - whereas the LR one would repeat x amount of times.
Post #83294 7th Aug 2011 9:33am
dgardel
Italy
But if you push for washing and hold it do 3 strokes.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #83305 7th Aug 2011 12:26pm
eutek
Grazie dgardel, your suggestion worked! Very Happy
Post #83307 7th Aug 2011 12:36pm
Just wanted to say a big thank you to the collective for this thread Thumbs Up Sounds like an excellent little mod so I've just bought a No.99 relay from eBay for the princely sum of £7.98 inc. postage Very Happy Darren
Post #83316 7th Aug 2011 1:37pm
lam1591
United Kingdom 2012 Defender 110 Puma 2.2 USW Tonga Green
I have also just purchased one from Ebay and hopefully it will be here in time for the weekend! It looks like an ace mod.
Thanks.
Smile
Post #83550 9th Aug 2011 10:33am
lam1591
Relay has arrived and fitted but wipers run constantly! Possible duff relay?
Thanks Crying or Very sad
Post #84099 12th Aug 2011 6:57pm
Just been out and fitted mine and it works perfectly. Took about ten minutes. For anybody wondering, the relay to replace is the brown one on the right nearest to the heater levers.
When you say they run constantly, do you mean just in the intermittent position or that you can't turn them off?
If the former, then it could just be that the last time it was programmed, it was done so really quickly so that the delay has been effectively set to zero. Try letting them run for a few seconds, turning them off and then turning back on again. This should reset it. Darren
Post #84112 12th Aug 2011 8:03pm
lam1591
Hi LandRoverAnorak
I fitted the relay turned the ignition on and switched the wipers to intermittent and they wipe constantly. If I put the wiper switch back to the off position the wipers still keep going, the only way to stop them is to turn the ignition off. Rolling Eyes
Thanks
Post #84118 12th Aug 2011 8:15pm
Hmm, doesn't sound good then. You sure it's in the socket the right way around? Darren
Post #84143 12th Aug 2011 9:31pm
lam1591
Hey LandRoverAnorak
I looked at it and it will only fit one way with the terminals are set up.
Big Cry
Post #84144 12th Aug 2011 9:49pm
Oh dear. Definitely not good Sad Darren
Post #84154 13th Aug 2011 12:17am
lam1591
Hey all,
Just fitted my new relay and still no good Big Cry When I put the old unit in it all works fine. Any ideas? I have been trying vw relay 99 part number 375 955 531 I've tried two now and no luck.
Post #84865 17th Aug 2011 6:04pm
That's exactly the one I'm using without any trouble:
To be honest, given that they seem to work for others too, I can only think that there's something strange about the wiring in your vehicle. Sorry, can't be much more help than that Sad Darren
Post #84911 17th Aug 2011 8:49pm
lam1591
Hello LandRoverAnorak,
How many pins has your relay got? I'm not sure if it makes any difference but my 99 relay is half the size of the one shown in your pic and the part number is stamped into the side not printed. Just wondering if the one I have is a newer version?
Post #84939 17th Aug 2011 10:10pm
