![]() | Home > Maintenance & Modifications > Intermittent Front Wiper- variable delay |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
And used it in anger today [been drizzly all bloody day] .... what a brilliant mod ![]() |
But if you push for washing and hold it do 3 strokes.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 ![]() ![]() ![]() |
Grazie dgardel, your suggestion worked!
Just wanted to say a big thank you to the collective for this thread
![]() ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
lam1591 Member Since: 07 Aug 2011 Location: Wiltshire Posts: 15 ![]() ![]() ![]() |
I have also just purchased one from Ebay and hopefully it will be here in time for the weekend! It looks like an ace mod.
Thanks. ![]() |
Relay has arrived and fitted but wipers run constantly! Possible duff relay?
Thanks ![]() |
Just been out and fitted mine and it works perfectly. Took about ten minutes. For anybody wondering, the relay to replace is the brown one on the right nearest to the heater levers.
When you say they run constantly, do you mean just in the intermittent position or that you can't turn them off? If the former, then it could just be that the last time it was programmed, it was done so really quickly so that the delay has been effectively set to zero. Try letting them run for a few seconds, turning them off and then turning back on again. This should reset it. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Hi LandRoverAnorak
I fitted the relay turned the ignition on and switched the wipers to intermittent and they wipe constantly. If I put the wiper switch back to the off position the wipers still keep going, the only way to stop them is to turn the ignition off. ![]() Thanks |
Hmm, doesn't sound good then. You sure it's in the socket the right way around? Darren
Hey LandRoverAnorak
I looked at it and it will only fit one way with the terminals are set up. ![]() |
Oh dear. Definitely not good
Hey all,
Just fitted my new relay and still no good ![]() |
That's exactly the one I'm using without any trouble:
![]() To be honest, given that they seem to work for others too, I can only think that there's something strange about the wiring in your vehicle. Sorry, can't be much more help than that ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Hello LandRoverAnorak,
How many pins has your relay got? I'm not sure if it makes any difference but my 99 relay is half the size of the one shown in your pic and the part number is stamped into the side not printed. Just wondering if the one I have is a newer version? |
