Home > Td5 > Error codes |
Is the light showing on the dash
if not as Vogler and Clive state, both of mine have codes related to A/c and 06 one ABS but not LR fitted Last edited by dorsetsmith on 10th May 2018 10:25am. Edited 3 times in total |
10th May 2018 8:54am |
Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309 |
AFAIK that's normal, our MY06 Td5 does it too.
Greetings, Joris |
10th May 2018 9:24am |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
Normal behavior, those functions are supported by the ECU and if not used will produce the errors shown.
There's no way to turn the functions off if unused so the errors will always reappear immediately if cleared, does no harm though. |
10th May 2018 10:12am |
TJH1985 Member Since: 22 Aug 2016 Location: Midlands Posts: 238 |
Same here a Nanocom throws them up, but LR diagnostics don't presumably because its aware of what the car was built with and masks them out
10th May 2018 10:27am |
Kst80 Member Since: 28 Aug 2016 Location: Essex Posts: 81 |
Thanks all, I shall no longer worry!
Cheers. Kev. |
10th May 2018 11:20am |
No lights just a couple of routine checks showed them. Thanks. |
10th May 2018 11:21am |
Dorsetsmith,
A learning moment seems to be lurking around the corner... What would you be thinking of if the amber EML does show? Greetings, Joris |
10th May 2018 11:51am |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 625 |
ABS, aircon or auto gearbox codes are there because these functionalities are enabled in engine ECU configuration. The only way how to disable them is modification of the configuration map - similar to remap of the fuel map. Not easy. There is no way hot to do it with diagnostics. I have been several times asked by local MOT, to help them with these, or at least to help the understand, that this is not a problem. Here in Czech republic Defender is a bit rare car, so they have only limited experience. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
11th May 2018 7:03am |
