Home > Td5 > Error codes
Kst80
Error codes
54 plate TD5 has twice thrown up error codes relating to ABS and Aircon, none of which the vehicle has.
Any ideas why?
Thanks in advance.
Kev.
Post #706363 10th May 2018 9:42am
dorsetsmith
Is the light showing on the dash Question
if not as Vogler and Clive state, both of mine have codes related to A/c and 06 one ABS but not LR fitted
Post #706367 10th May 2018 9:54am
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
AFAIK that's normal, our MY06 Td5 does it too.
Greetings,
Joris
Post #706379 10th May 2018 10:24am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
Normal behavior, those functions are supported by the ECU and if not used will produce the errors shown.
There's no way to turn the functions off if unused so the errors will always reappear immediately if cleared, does no harm though.
Post #706382 10th May 2018 11:12am
TJH1985
Same here a Nanocom throws them up, but LR diagnostics don't presumably because its aware of what the car was built with and masks them out Thumbs Up
Post #706384 10th May 2018 11:27am
Kst80
Thanks all, I shall no longer worry!
Cheers.
Kev.
Post #706393 10th May 2018 12:20pm
Kst80
No lights just a couple of routine checks showed them.
Thanks.
Post #706395 10th May 2018 12:21pm
Vogler
Dorsetsmith,
A learning moment seems to be lurking around the corner... What would you be thinking of if the amber EML does show?
Greetings,
Joris
Post #706399 10th May 2018 12:51pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
ABS, aircon or auto gearbox codes are there because these functionalities are enabled in engine ECU configuration. The only way how to disable them is modification of the configuration map - similar to remap of the fuel map. Not easy. There is no way hot to do it with diagnostics. I have been several times asked by local MOT, to help them with these, or at least to help the understand, that this is not a problem. Here in Czech republic Defender is a bit rare car, so they have only limited experience. "Drobek" = The Small One - Discovery 2, "BlufĂ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #706529 11th May 2018 8:03am
