Home > Td5 > Rattling gearstick |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20466 |
Possibly UJ’s. Try greasing them and see if there is any difference at all before exploring further.
If that is it ultimately they’ll need changing though. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
9th May 2018 10:37am |
jonny2tanx Member Since: 06 Jul 2014 Location: Harpenden, Herts Posts: 156 |
Make sure that your gear lever is tightly fastened to the pivot pin shifter. I think it needs a 17mm spanner. Mine was loose and produced a sizzling type of noise
10th May 2018 9:43pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 942 |
What he said... kinda common rattling point. Also be sure your shift ball bushing is not worn and needing replacement. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
11th May 2018 12:00pm |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1000 |
I have this issue on my 90 td5, recently had a slick shift fitted which has reduced rattle a bit, probably due to new parts and bias springs being adjusted but I still have some rattle, my mechanic did say that the gearstick turret was worn and properly contributing so will replace that. Maybe worth checking Terry.
11th May 2018 12:05pm |
Terry Member Since: 20 Nov 2017 Location: wales Posts: 19 |
Nice one mate.
As I also have a slick shift fitted. The turret sounds a feasible culperate as it's original and done about 200.0000 miles. Will look into that. |
11th May 2018 5:16pm |
