Home > Td5 > TD5 Starting problems
drinkdrinkdrop
I've got a progressively worsening problem starting my 2005 TD5 110. It cranks fine and once going runs fine (possibly lacking abit of top end, acceleration drops off above 70 odd) no missfires on anything like that.
Initially it would start everytime but occasionaly with a really lumpy idle just after starting, almost as if it wasn't running on all cylinders, the problem then goes away as soon as you applied any revs.
This got more and more frequent then you needed to rev it as you started it to coax it into life, now sometimes it just wont start, the problem seems more common when it been run recently so if I drive turn it off then try to restart the chances are low whereas left overnight I can usually get it going in the morning.
Changed the fuel filter which gave me 2 days of perfect starts then the problem returned, pump doesn't seem any noisier from the cab but was pretty loud when I was priming it after the filter change. Checked ECU plug which was clean, injector harness was changed a few months back, ran a new earth from the ECU to the transfer case as a precaution. Batteries are less than a year old.
I've got a pressure gauge coming so I can check the fuel pressure in a few spots but anyone got any other ideas?
Post #706183 9th May 2018 9:59am
dorsetsmith
injector seal (is sump oil level increasing)
Post #706185 9th May 2018 10:22am
drinkdrinkdrop
It's definitely possible, no obvious smell of diesel but i'll get them changed and see what happens. Cheers
Post #706195 9th May 2018 11:15am
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Hi
see my post in general section about non starter.
Tommo
Post #706234 9th May 2018 5:16pm
drinkdrinkdrop
Right had seals and washers changed and a new injector loom, also changed the fuel filter return valve, this has caused a slight improvement.
A couple of oddities we’ve noticed
The only chance of starting it comes on attempts when the coil light comes on, if the first start fails the on subsequent attempts the coil light never appears and turning the key will result in cranking only with no hint of a start. You then need to turn off and wait for all the relays to click off before retrying
With the above taken into account I can usually get a start by turning to pos 2 waiting 15 secs or so then starting.
Any other suggestions?
Post #706624 11th May 2018 6:19pm
Dieseljock
Scotland 2003 Defender 90 Td5 HT Zambezi Silver
Try snd bump start it, my mates old boys was having similar issues. Turned out the starter was corrupting the crank sensor signal
Post #706630 11th May 2018 6:45pm
drinkdrinkdrop
Right started fine this morning about 20 starts some close together some far apart so cold starting not the issue any more.
Took it for a drive for 25 mins mostly on full throttle a road, drive fine except still feels down on top end, I can get it to 70+ in 4th but not faster in 5th
Got back turned off then immediately back on and started fine, turned off again waited for relays to reset then the car will start only to stall after 3-5 secs whatever combination of clutch/throttle I use.
Ran some purge cycles and pump not too noisy and no gargles, then is some noise like a spurting near the fpr but no visible leak.
Just unplugged the coolant temp sensor and fuel temp sensor together and it fires again! So I’m assuming the issue is with fuel delivery so what’s next, pump replacement or any other checks?
Ps can you drive without coolant temp and or fuel temp sensors? For testing?
Post #706724 12th May 2018 10:49am
mk1collector
Try unplugging the MAF and see if you get your power back when driving. Ray
My build thread
Post #706737 12th May 2018 12:26pm
drinkdrinkdrop
Seems to run exactly the same with and without a MAF
Post #706930 13th May 2018 5:10pm
NickMc
Any codes present?
Post #707020 13th May 2018 11:30pm
drinkdrinkdrop
No codes apart from the missing aircon, abs, rev counter etc
Tested fuel pressure 4bar at the rail in all situations the pump is running, checked amp draw and it's a steady 11.5 which seems to be with the acceptable range. Gave all the under seat relays a clean but will replace them as a matter of course.
The starting problem has now developed some consistency. engine temp low, starts 100% of the time. engine temp high, it starts then immediately dies every time, wait for it to cool down and it'll start fine. Here's a video of the issue
&feature=youtu.be
Next plan is to get a new temp sensor, i'll then unplug the fuel and engine temp sensor wiring and connect to the new sensor this should determine whether it's to do with engine/fuel temp after a drive or a hot component/electrical short when hot type issue somewhere
Post #707247 15th May 2018 8:14am
MadTom
Try to heat the ECU itself, not just the engine. I have seen some ECUs with heat related problems (poor solder joints). "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #707250 15th May 2018 8:21am
drinkdrinkdrop
Couple more bits tried today
Swapped temp sensors for cold ones, no change
Tried bump starts, same thing happens the engine starts runs for a few seconds then stalls regardless of whether you clutch it or not
Changing CPS tomorrow, fingers crossed
Post #708098 19th May 2018 5:37pm
NickMc
Can you show us any live data?
You can’t really get much definitively with a volt meter, you could try and if it has a mid max scale possibly.
Do you find key on key off and building the pressure makes a difference?
Post #708102 19th May 2018 6:20pm
drinkdrinkdrop
Not got anything right now, picked up an icarsoft lr2 but was useless, would basically only show codes, nothing useful. Going to pick up a Hawkeye total or a nanocom on next week, see what that shows up
Post #708107 19th May 2018 6:48pm
